Question about Cell Phones
Please tell me how I program the memory so I can make long distance calls without dialing all the numbers each time.
  • richard_midd Sep 02, 2010
    Thank you. The cordless phone is a Toshiba Model FT-8001.Please type me the STEP BY STEP process to store my prepaid phone card information , then i cna enter the long distance number. Can you scan the ACTUAL PAGE IN THE TOSHIBA INSTRUCTIONS DEALING WITH THIS?
    Thank you.
  • richard_midd Sep 03, 2010
    Please see previous note. I need the instruction sheet from my Toshiba phone on how to put my phone card # in memory.
    Genius:
  • 1,456 Answers
Hello
What you can do is to type the number in your phone and save it for example +123456789 withe the persons name or the name you call the owner of the number in question
You can also save the assign a speed dial to the number so that whenever you want to call the person you just long press a number for example long-pressing 3 can will automatically dial the number assigned to number 3.
To assign a speed dial go to your contact settings,select speed dial and follow the instructions given
Posted on Sep 03, 2010
  • Cell Phones Master
  • 17,130 Answers
You have not mentioned the model/make of the set. But on a universal level just type the phone number into the memory key and store. fo easy dialling , fast dialling choose from 1-9 in your keys , as the priority of your contacts and set them in.
it will only be easy to rememeber that the number has tobe stored into a location .So choose, select and store.
For further clarification reply with make /model, the menu keys. program keys and store keys.
Posted on Sep 02, 2010
    President:
  • 2,047 Answers
Various cellular devices with different features which come with them. Although most devices dont have the particular feature you request.
A universal way to get this done without having to dial all the numbers all the time will be to save the contact details on your mobile device.
If the details have been saved in your phone book all you have to do is search for the name with which the details are saved and dial.
Hope this solution has been helpful?
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
What do i dial before the long distance number a 1 or a 9
Depending on your phone service. if you pick up the handset and dial a local number without using 1 or a 9 it should be fine. You basically would dial how you would make a call from your phone. Long distance included. If it is a long distance number from your phone, it would be for the fax machine too.
Feb 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
How to delete numbers that are stored leaving the memory storage empty?
Store a new number in the same location of that which you wish to delete. Otherwise, just don't use the buttion.
The procedure is
Pickup handset
Hit Store Button
Push numbered buttons for phone number
Hit Store Button
Put handset back on cradke
Record number
Oct 01, 2008 | GE 29318GE1 Corded Phone
Brother 7220
You might need to dial 9, followed by a comma or pause, if you are faxing from inside an office.
You might need to dial 10 digits, if you live in a high density location in North America.
If you're dialing a long-distance number, the person paying for the line may have disabled long-distance calling - check with parents / spouse / boss / landlord, as applicable.
Sep 18, 2008 | Brother MFC-7220 All-In-One Laser Printer
Inserting pauses in fax dialing number
Try a comma or multiple commas and test the delay.
Sep 27, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
