Question about Hotpoint Washing Machines
Hi, my Hotpoint BWD19, washer dryer, washes but will not spin or drain. My hubby has checked the filter and hoses, no blockages. A friend said the carbon brushes have gone...? What could be the problem? Thanks JT London
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 03, 2010
Hi, the challenge is that it washes and wont drain through the hose until i remove the filter
Hi.
Check that the drain hose height and elbow setting is correct, or the problem will be giving by water re-fluxing into the appliance from the drain hose.
Access the filter and clean it.
Check for blockage at drain pump hose.
Replace the filter if you have not done it yet.
Check and clean the hose connected to pressure switch.
Here a general article that I wrote about no-spin problem: If you have no spin ...
Regards.
Ginko
Apr 19, 2011 | Haier XQG50-11 Front Load Washer / Dryer
Washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Mar 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius washing machine wont pump out the water
HI.
You need to check the pump filter.
Remove lower rear panel of washer.
Remove large black hose fastehed to bottom of drum
Remove hose onto pump, and check for blockage or obstruction here as well.
Check drain out let hose is not blocked.
Please rate my solution/.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
I have a Hotpoint WD420spin washing machine /dryer. It was on a regular cycle like normal but the water doesn't come out of the machine, the water doesn't seem to be draining even if i put it on a spin...
You need to clean the pump filter.
Remove large black hose from bottom of drum.
Remove and clean plastic filter inside hose.
Hope this helps.
Jan 01, 2010 | Hotpoint Dryers
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint First Edition WMA22 Front Load...
When rinsing/spinning the water comes out of the dispenser drawer
I see this is under the dryer section, i am assuming its a washing machine or washer dryer.
If its leaking from the dispenser during the filling stage, this could be a blockage in the dispenser or as simple as the water pressure is too high,
If it leaks during the spin on the rinse cycle, this is generally a blockage on the outlet area (normally the sump hose/filter) remove the filter if fitted and check for blockages, if ther is no filter on this appliance, you will need to check the sump hose, this is located under the machine, mormally a black hose from the tank to the drain pump, remove from the tank end and look in there, Finally it could be a blockage at the end of the waste hose (grey one) it quite often gets blocked at the sink end.
Hope this helps.
Regards
Sussex engineer
Please rate my help. Thanks
Oct 22, 2009 | Hotpoint Dryers
Spin cycle not draining
Hi-ya Brian
Probably blocked filter.
To locate and clean, remove rear panel altogether, locate large black hose at bottom of drum, remove from drum, and you will find the filter located inside the hose.
Check drain hose is not blocked also.
Thanks.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
