Question about Malber TD700 Electric Dryer
I need a 220 volt timer for Malber TD700 drier.
  • Malber Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 04, 2010
Quit working----we thought it was a motor---took motor off---it runs
if the heat has stopped check the main power and make sure there is 220 volts at the terminal block.
if the power is correct then next thing is to check the continuity of the heating element,and all the thermal cut offs if you find one of them with out continuity then replace that part.there is also a chance the main control board has failed as well as the door switch this also needs to be checked.
Nov 03, 2010 | Malber TD700 Electric Dryer
Where do I download manual for malber td700 dryer
You can download the manual for your device at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
May 02, 2010 | Malber TD700 Electric Dryer
Malber TD700 sensor tumbles but no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 05, 2010 | Malber TD700 Electric Dryer
Door switch has to be replaced
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer, a front load washer, or a dishwasher, I suggest you
go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as many other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you to a place that will help you solve the problem. Good luck with it.
Dec 07, 2009 | Malber TD700 Electric Dryer
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Malber Company - Italy. Address
need to find a manual for Malber WD8008
Oct 25, 2008 | Malber TD700 Electric Dryer
Opening the Malber TD700 dryer
Remove the two top screws on the back center (plastic part) with a Torx 20 screwdriver and the top will come off.
Jul 25, 2008 | Malber TD700 Electric Dryer
Malber dryer 2 years old
move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Jan 06, 2008 | Malber TD700 Electric Dryer
Malber TD700 Electric Dryer Logo
110 people viewed this question
Top Malber Dryers Experts
Dan Webster
Dan Webster
Are you a Malber Dryer Expert? Answer questions, earn points and help others
