I turn on my DVD player and it will say "f61" and turn off.
  • 480 Answers
I you can try this option:
1. Unplug the power cord.
2. Wait five minutes to let residual power dissapate from unit,
3. Use electronic contact cleaner with thin red spray tube and spray inside each input/ouput jack in back,
4. Clean each patch cord lead and also do same for speaker output connectors.
5. Do the same to AM/FM antenna outputs. The contact cleaner has high flash and evaporates quickly. (also try to use compressed air in can with same red tube).
Cheers!!
Posted on Sep 02, 2010
F61 sa ht 540
electrical problem caused by
Power digital amp IC op or DC output voltage abnormal.
need servicing
Nov 04, 2013 | Panasonic DVD-F61 Multi-disc DVD Player
I have a SA-HT730. i get the F61 error code and then turns off. Please help
Check this site. It has details about the error codes to Panasonic HTs. http://electronicshelponline.blogspot.com/
Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 15, 2013 | Panasonic DVD-F61 Multi-disc DVD Player
When turning on the Panasonic DVD player the unit stays on for 3 seconds and reads "Hello", then reads F61 and turns off. What causes this and how can it be resolved?
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
May 18, 2010 | Televison & Video
F61 error message
F61 IS THE ERROR CODE FOR A FAULT IN THE AMPLIFIER STAGE OF THE UNIT, if the power fan or supply is okay then THE MOST LIKELY CULPRIT IS THE AUDIO OUTPUT IC, WHICH IS A MULTI LEGGED DEVICE SCREWED TO A PIECE OF METAL USED TO COOL IT, IN PANASONICS ITS PREFIX WILL PROBABLY BE "RSN" BUT IT COULD BE "STK", MAKE A NOTE OF THE NUMBER AND SEARCH ON LINE, DONT FORGET TO CLEAN OFF THE OLD HEATSINK COMPOUND ON THE HEATSINK AND REPLACE WITH FRESH.f61 means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit
Sep 28, 2009 | Panasonic Televison & Video
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
F61 on dvd
audio amplifier IC damaged need to be replaced
Jul 23, 2009 | Panasonic DVD-F61 Multi-disc DVD Player
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
F61 code on SA HT540 system
i think it means that the cooling fan is faulty.
cheers Mark
Jan 06, 2008 | Lands Phones
22 people viewed this question
 Grubhead
Grubhead
