How to remove keypad gateway mx3701 for cleaning
Soda spill on keys some stick some don't work
    Problem Solver:
  • 7 Answers
Your best bet is to buy a new keyboard they are inexpensive and it is not worth it to try and repair it. it's not really a good idea to drink anything around any electronic devices !!!
Posted on May 12, 2008
I spilled soda onto the key pad. Three keys are sticking badly. How do I clean it?
Gently pry the key upward with a butter knife and clean underneath and the key with a 90%+ rubbing alcohol.
May 18, 2016 | Computers & Internet
Spilled soda on toshiba laptop m505, keyboard is not working. keys don't stick anymore but not working. what do you recommend to fix it?
You need a new keyboard. The sugar in the soda caused the damage and will further corrode the keyboard.
I would also recommend that you clean the area where the soda may have spilled to on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 14, 2011 | Toshiba Satellite A135-S4527 Notebook
My keys are sticking due to orange juice being spilled on them. My IT guy at work said I could order another keyboard or keypad, how do I do that and where can I order it from, he will change them out for...
Go to ebay and enter your computers info"" make and model...alot of choices will pop up.Select the one that suits you.It's really that easy.I only hope none of that liquid went futher than the keypad...Goodluck
Apr 07, 2010 | Gateway 2520915 Keyboard
DRIVERS FOR MX3701 MOTHERBOARD
try here hope it helped http://support.gateway.com/support/drivers/search.asp?param=MX3701&st=kw
Dec 15, 2009 | Gateway MX3701 MX3702 MX3704 Motherboard -...
HOW do I remove the keyboard on a Gateway Laptop Model T-6330U, I spilled juice on keypad and heard sizzling when I restarted, and monitor fadded out. An external monitor works fine, and computer boots up...
You could send the laptop in for repair but it could be quite pricey, it sounds like the LCD is toast. If your keypad still works using an external monitor then you won't have to replace that.
Sep 20, 2009 | Gateway T-6330U Notebook
Spill soda on my laptop keyboard
It is likely the only problem is that the soda is causing the keys to stick. There is probably no damage to any other internal components. Usually, laptop keyboards have a metal-based frame/tray that will protect the internal components from minor spills.
If you want to get rid of the cracking sound, you'll need to purchase a replacement keyboard from the laptop manufacturer or another source such as eBay, and then remove the sticky keyboard and replace it with the newly purchased one.
Mar 23, 2009 | Toshiba Satellite L305D-S5895 Notebook
Sharp calculator
I had the same problem happen to me. What I did was carefully take the calculator apart using a T-10 Torx screwdriver to remove the back cover. I then used a compressed air can and blew air into all the crevices and holes in the calculator. I was able to dry almost all of the soda the spilled, however some of the soda dried and turned into somewhat of a sticky mess. I was able to carefully wipe the sticky parts clean with a tissue. After doing all of that my calculator worked perfect.
Nov 15, 2008 | Texas Instruments TI-84 Plus Silver...
3 buttons on Keypad don't work
If You haven't already, open the phone remove the battery and SIM. I believe you can also remove the front face plate and key pad. Make sure the contacts behind the key pad are dry as well as the underside of the pad itself. Leave the cover and face plate off to allow to dry for as long as possible. If the phone was too wet it may not recover. If it does not you will have to replace it. The cheapest option is a go phone. You can get the Nokia 6010 refurbished online at Cingular for $29.95 and use your current SIM and will be good to go. When you order You will need to select a go phone plan but you do not need to activate it. Good Luck
Mar 19, 2006 | Nokia 3595
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
