Question about GE WBSR3140DW Top Load Washer
The cold water just drips into the machine. We took the hose off the back and cleaned it out and it worked for a day. Now I think there is something plugged inside the washer but I don't know how to get to it.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 03, 2010
I cleaned out the water from the drip pan, cleaned out the pipe and it started working. Now the drip pan is full again and the furnace is not working
something has to come out the other end. where do you think the water is going? it has got to go outside, if not it will end up in the condensate tray and shut off your unit if you have a float switch.
Sep 03, 2012 | Goodman Heating & Cooling
The cold water just drips in very slowly while the warm water enters quickly
Your cold water screen is clogged. You have to take the cold hose off the back of your washer. Look in the back of the inlet valve you will see a screen. Pull it out and clean it. Then put it back in
Jul 13, 2011 | KitchenAid Washing Machines
My hot water works fine. The cold water only drips in. I took off my cold water line and cleaned the filter. Still only drips. Any advice would be helpful. Thank you.
You will need to replace the water inlet valve. If you could post your model number I will be able to direct you to the part you need.
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
The cold water is not flowing well into the machine. It is just dripping. I've swapped the hose with the hot (this has not helped). The hose, when disconnected from the back of the machine seems to have...
Hi just read your posting.Now the place you unscrewed the hose from on the machine end is the water valve.If you look at the water valve from the back of the machine you should see a plastic filter inside the water valve.Clean this filter if it is blocked.Now refit hose to machine and try a fill cycle again.If it still has inadequate water flow then the water valve needs replacing.If it needs replacing I can guide you step by step to replace the valve.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hi the cold water just dribbles into the tub. if I
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Washing Machines
My washing machine slowly fills with cold water after use. It is a
Make sure that you shut off water to your washer before doing so. If you have water shut off valves by your washer you can use them. A warning when you use your valves and when you do get fixed, it will more than likely it will dripped some water, when you turn the water back on, so watch for that. It shuold stop after couple of days. Your mixer valve on your cold side. It could be your mixer value is plugged up with some dirt from your water source. It could be that your screen on your hose is plugged and just cleaning to make it work.
Dec 06, 2009 | Washing Machines
Cold water only drips into washing machine
try turning off water and remove hoses fron faucet and back of machine and check for plugged screens in hoses or back of machine clean and reinsall and turn water back on this may fix problen
May 25, 2009 | Kenmore Washing Machines
Cold water just drips, hot is fine, good pressure.
turn off water then remove hose. filter is in the fitting on the machine where the hose connects. pull out filter and clean or replace it
Apr 19, 2009 | Maytag Dependable Care LAW9406
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
E10 error code?
We had the E10 error code. I took off the water intake hose as the washer and the screen there was full of sand from our well. I cleaned the screen out and the code disappeared.
Apr 25, 2008 | Frigidaire Affinity ATF7000ES Front Load...
GE WBSR3140DW Top Load Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
