Question about Acer Aspire 3680 Laptop
Computer wont startup it cycles and repeats sony vaio pcv rx560
My computer will not start up. It boots and and gets to a screen where it asks if I want to start windows normally. I do that and then the window xp logo appears and then it reboots and starts all over again.  Right after the window xp logo appears something runs across the screen and disappears to fast to see what it is. I have norton internet and antivirus and the sp2 pack of windows xp installed. However, I have not installed anything recently. Just prior to the problem my comcast high speed internet went down and when it came on that is when I had the problem. I can boot from the CD-rom and have done a check with a cdrom norton and I have no viruses, but it is not the latest viruses on the disk and I dont know how to down load them onto the cdrom from norton site. I am having the same problem however mine won't boot in to safe mode. Prior to this occurring I have been having problems with my battery holding a charge so I could only use it with it plugged in to the wall, I left my machine running overnight and hadn't noticed the power plug had come out of the wall. When I went to power it on this morning all I get is a message telling me that my machine wasn't powered down properly, if it was due to a battery problem select normal boot mode. No matter what boot mode I select it comes back to this screen.
  • radarguy1965 May 10, 2008
    I can't get it to go into safe mode, no matter what option I select it just comes back to this screen.
  • denmont Jun 13, 2008
    Computer wont startup it cycles and repeats dell windows xp. even in safe mode.
Ok, i do in fact know what your problem is, your OS (Operating system has crashed. this has happened to me several times. what you need to do to fix it, get a windows xp, or vista disc, and put it in the drive, u may want to press f2, and enable f12 setup, and put the disc in from the options on that selection menu, just wait for it to reinstall your software and your done, if u dont have a windows disc then ur screwed lol. just buy one.
Posted on Sep 29, 2008
    Novelist:
  • 173 Answers
Hi radarguy,
There several possible reasons why your computer reboot after getting to the windows screen. one is a corrupt or incompatible driver that was installed on your system, try to boot on safe mode(press F8 during the POST(power on self test) for newer computer this will come as a flash on your screen, when you are being prompted how to you want to start windows just the safe mode then check if your computer will start up properly if it is then a driver or an application may have cause the boot problem try to perform a system restore and put the state back when it was working properly you can check out this link if your problem will fall on one of the following problem http://www.aumha.org/win4/a/shutdown.htm
Now if safe modem will not fix the problem, the boot.ini maybe corrupted, check this link on how to re-install/fix corrupted boot.ini http://support.microsoft.com/kb/330184 this process requires your Windows installation CD.
Hope this will help you solve your start up problem with your computer.
Regards
Posted on May 10, 2008
Bought used computer no disc I wont to clean it out and restore factory settings
if the computer is a sony vaio
start the computer and try F8 or F10 repeatedly until the the
ADVANCED BOOT OPTIONS screen appears
if that doesn't work you may have to contact sony vaio for recovery disks
Sep 25, 2013 | Sony VAIO PCV-W1 PC Desktop
Installing 500 GB EIDE HD in a SONY PCV-RX560
what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Problem with Sony Vaio pcv-rx860 (screen goes black at startup)
I would suggest first to try to take one stick of memory out and try to boot up the pc. Sometimes, one or both of the memory sticks can go bad or the memory slot on the motherboard itself can go bad. If that is not the case I would then remove all of the usb connected to the computer and last i would test the power supply.
Apr 16, 2009 | Sony VAIO Digital Studio PCV-RX860 PC...
Comp stuck on vaio screen
It might be a motor going bad, as in a HDD or fan. Try to pinpoint where the noise originates. Is it coming from the speakers or somewhere else?
Dec 28, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
Nov 14, 2008 | Sony VAIO PCV-W600G PC Desktop
Computer won't come on
??????????? not enough info.
No power?
No screen???
Aug 07, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
Xp reboot
plz try to boot in safe mode(press f 8 when the system reboot in bios screen), if the the problem persists than you have to repair or reload the operating system
Jun 24, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
Hp wont load up
Your CMOS battery should have drained. Replace it.
Jan 03, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
A Open Computer running Windows XP is
run with safe mode and go with admin privileges then when u are in go START -RUN - TYPE THERE ( MSCONFIG ) -startup and desable all startup items and restart the pc!!!
Let me know if u get help OK?
Oct 29, 2007 | Sony VAIO PCV-RS530G PC Desktop
Acer Aspire 3680 Laptop Logo
332 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
