FixYa.com
Tags:
Nikon Speedlight SB-800 TTL Flash
Zoom range 14-17mm
posted by KvMeg on May 10, 2008
Hi, my problem is: my SB800 accidentally works in zoom range 14-17mm when previously the whole range was available. How can I switch it back to standard range 24-105mm? I’m using Nikon lens 18-70mm.
Thank you, Meg
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 22, 2008
Not Rated (0)
tjzteddy
Rank:Wiz Wiz
Rating: 89%, 25 votes
make sure the diffusion dome and the built in wide angle adaptor are off. If the diffusion dome is on, it will only work as 14mm and 17mm without the diffuser but with the wide angle panel.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Flashes problems?
SB 800
Where can I get my SB800... Answer This...
i want a complete manual
i want a complete manual for... Answer This...
Flash wouldn't stop flashing
Hi.I have been using sb800 for... Answer This...
nikon sb800 speedlight
sb 800 misfires. I have net... Answer This...
Nikon SB800 Flash
I have 2- SB800 Flashes. It... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
