Question about Refrigerators
Noisy refrigeration without a icemaker.
My GE refrigerator with a bottom freezer was purchased in 2006. It is extremely noisy. I did not choose the icemaker but it seems to cycle as if it was making ice. The cycle is very noisy.
  • 770 Answers
Lift the arm up on the icemaker to shut it off some models have a switch on the side of the ice maker you can turn off as well a green indcator light
Posted on May 10, 2008
My Amana bottom freezer model # BB20VSE, serial # 0006289684, mfg # P1321301WS has become increasingly noisy when the compressor(?) turns on. This started over a year ago and now is extremely loud. Thank...
Ah this is an indication that your condenser has become dirty, or blocked, or the fan motor is not working or the air flow is restricted.
The noise is generated when the compressor cycles off and sudders to a stop
Mar 24, 2011 | Amana ARB9058CS Bottom Freezer...
I have a GE bottom freezer model TDC18PAAWW. It seems to be working fine but has begun to produce a clunking noise when the compressor starts and stops. Do you have any idea how serious this is and what...
just keep an eye on your fridge temps over the next few weeks if there ok then its just getting noisy with age but if it doesnt hold its temp then the compressor is on its way out but the compressors very rarely fail i would say its just getting older & noisy.
Jan 12, 2011 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The motor is constantly running and so so noisy and the outsides of the freezer get extremely hot
Unit is low on gas. You may be able to have it regassed but it will probably need to be done again at some time in the future as there must be a leak somewhere in the gas circuit.
Jul 07, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
The temperator is uneven
Our side by side GE model # GSS25SGPESS is not cold on the food side. the temp in the refrigerator is 48 degrees.
Apr 18, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Fan noisy
Thank you for contacting me, the noisy fan unit was resolved when the freezer
was defrosted'
Jun 26, 2008 | Bosch KGU32124 Bottom Freezer Refrigerator
Noisy Amana ABB2227DEB
The motor is an "auto damper" that opens/closes to let cold air from the freezer comp. into the refer comp. depending on the temp. There is nothing you can do for maintenance, the little motor runs the damper when needed automatically. Some motors are quiet, some are noisy (grind grind grind) as the open and close. Sort of the nature of the beast, if you're lucky you get one that stays quiet.
Feb 26, 2007 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
