Question about Goodman Heating & Cooling
I replaced the capacitor on the unit. I still do not have the fan blowing on the unit. The capacitor was bad to begin with. Any advice?
  • b52delta757 Sep 02, 2010
    I reset the circuit breaker. The fan came on but at low rpm. The circuit breaker tripped. Any advice?
  • Goodman Master
  • 17,130 Answers
Can you check on the fan with the multimeter to see if the coils show continuty.If the capacitor was bad there is a possibility of the main winding heating up to burn and open.so check this out.
Posted on Sep 02, 2010
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
Fan condenser unit wont run
This is usually a bad capacitor or bad fan motor. The capacitor is located inside the electrical panel on the outside unit. You can check these by using a meter that measures Mfds (Microfarads), most of the time you can visually see the capacitor swollen or blown. The fan motor can be checked by a meter that measures ohms, really high ohms are usually bad. If you can't spin the fan blade easily, then it's locked up. What usually happens, the capacitor or motor windings go bad, doesn't spin the fan blade, overheats the compressor so it kicks out on thermal protection till it cools back down, and sometimes the motor will overheat and go into thermal protection also. Just make sure you are getting the 220v to the outside unit too, but shut all power off before doing any trouble-shooting. Hope this helps, feel free to ask any questions!
Jun 30, 2012 | Heating & Cooling
Central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Jun 22, 2012 | Heating & Cooling
I have an 12QZ22TA model. It's blowing warm air. How do you put in freon?
Only an EPA certified Technician can add refrigerant. There are other possibilities why it is blowing cold air.
1. Thermostat is bad (disconnect the power, remove the thermostat, place a jumper wire on the two terminals) Unit starts to cool bad thermostat.
2. Capacitor is bad (look for oil or swelling) looks like a can with terminals.
You can test with a meter.
Instructions Things You'll Need
  • Standard multimeter
  • A/C compressor capacitor
    • 1 Turn the A/C unit off along, and unplug it from, the wall to prevent any power surge to the unit when handling the internal devices. Locate the capacitor inside the unit. Capacitors will come in varying shapes; some will look like either a round or oval cylinder with two or three power terminals on the top. Air conditioners can have two capacitors -- one for the condenser fan and one for the compressor -- and are called dual-run or dual-rated capacitors.
    • 2 Place the probes on the terminals for a run capacitor with two terminals. If the capacitor is a dual-run capacitor with three probes, connect one probe to the herm terminal and the other to the common terminal. You can check the capacitance of the fan for a dual-run capacitor by connecting the probes to the fan and common terminal.
    • 3 Turn on the multimeter and read the display screen. You will see two readings, one for the condenser fan and the other for the compressor. Readings will be in micro farads and seen as the letters "mfd" or "uf."
    • 4 Replace a capacitor if the reading is below manufacturer standards. You can find the required micro farad for the capacitor either marked on the device or in the air conditioner's installation manual. Refrain from testing any capacitor if it is leaking, has corroded terminals or the capacitor unit bulges. Replace it immediately.
Aug 01, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
The AC fan does't want to begin to spin on its own. if I give it a little help, it will begin to work. Why wont it start on its own the fan will spin very easily and is not restricted at all it...
Hello, sounds like you have a bad capacitor, the capacitor gives the motor a boost and improves the running effeciency of the motor. Replace the capacitor it should fix the problem.
Mar 18, 2011 | Frigidaire Heating & Cooling
Not blowing cold air. Checked outside unit and looks clean but fan not turning
You may have a bad capacitor, fan relay/contactor, or motor. Check the capacitor for the fan, if the capacitor is ok, then check the fan relay/contactor. If this is ok, then the fan motor is bad.
Aug 02, 2009 | Goodman CKL36AR36 Air Conditioner
Interthrm ac unit on but no fan blowing. is there an easy fix?
if your indoor fan is not running you have one of two problems either run capacitor is bad or motor has gone bad. Not sure if you can get a capacitor from home depot you can check make sure its at least a 440v and get exact MFD rating usually they are 5-7.5mfd
Jul 26, 2009 | Heating & Cooling
Compressor fan motor runs backwards
Most likely a bad motor or bad capacitor. I would check the capacitor first as this is probably a $20 fix. The fact that it runs in the correct direction but at a reduced speed really leans hard to the capacitor.
Good Luck and hope this resolves things for you. Let me know.
May 09, 2009 | Goodman CKL24AR24 Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
