Question about Watches
I need instructions for Jaga watch m555 - Watches
Guys its simple help me how can i fix my watch?its going two minutes back jaga wr100 m orange
Press button. Add two minutes. Press set. New time correct.
Feb 08, 2017 | Watches
Am....guys i want to know if my watch going 2 minutes back it will be forward after 28 minutes???and how can i fix it?? **its 2 minutes back 4 hours now.my watch is a jaga wr100m orange
You aren't making a lot of sense with this post either. This is a normal quartz watch. It isn't connected to a time server, so you need to correct it.
In the image, the watch says it is 9:41. If the correct time is actually 9:43, you advance it 2 minutes. You say 'back', but the better terms for a watch or clock are 'slow', or 'fast'. Your watch is 2 minutes slow, or two minutes fast? If the correct time is back, (the watch is fast) you need to advance 28 minutes.
Post here as a COMMENT, DON'T start a new post!
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How to set time jaga 100m
It's described here: http://support.radioshack.com/support_radios/doc40/40189.htm
Jun 26, 2014 | Casio DW290 1V Classic Alarm Chronograph...
JAGA AD0919 WATCH
Hello
happy new year
It is my greatest joy to say hi to you on this beautiful and lovely day.Having said this,it is my wish to establish a long lasting and strong friendship with you.'Friendship is the greatest blessing on earth and a friend is a gift our heart treasures.I hope you accept my proposal and i wait for your reply soonest for introduction.Yours miracle
(miraclelarrycumbu@yahoo.com
Oct 15, 2012 | Bulova Watch
JAGA AD0919
Press and hold the mode button. Does a digit flash? If not try a "set" button. Once you get a digit flashing, you use one of the other buttons to change the digit. You can't do any damage so experiment.
Battery Replacement for JAGA Watch
just remove the back cap of the watch and remove the battery and it with the same one or with the same model number...
Mar 03, 2011 | Watches
I have a jaga digital watch. It has a light/adjust/set and mode button. How do I set it for the time and then use the timer. it has a 8 lap memory. Hannah
hey. so you hold the set button down when your on the time mode, then the hour digit flashes and press the adjust button till its the right time, then the mode again to flash the minutes, then adjust till its the right number then that should be like it. once youve got the time and date and everything right press set and it should be done. hope this isnt like rela late or anything. x
Apr 19, 2009 | Watches
Watches Logo
189 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
