Question about Canon imageCLASS D880 All-In-One Laser Printer
I have an Canon imageclass D880 - is it windows 7 compatiable?
  • 395 Answers
There is a windows vista 32 bit driver that should work fine with it at cannon webs site
http://canon.driversdown.com/Canon-driver-list/s_475_1.shtml
Posted on Sep 03, 2010
Canon imageclass d880 info
What OS is the Vaio running? Canon has drivers for the 32-bit versions of Windows XP, Vista and Windows 7. The Windows 7 driver may work with Windows 8 32-bit in the compatibility mode. However, most computers with Vista and later versions of Windows have the 64-bit OS; the exception are some machines that came with 2 GB or less of memory when new. Canon did not create a 64-bit driver for the imageCLASS D880. To check your OS version, go to the System Control Panel. (XP, Vista and Windows 7: Start > Control Panel (in the right hand column) > System and Security > System. In Windows 8: press the Windows key + X and do the same steps.) Then read the version information, if x64 is included then the 32-bit drivers won't work.
If you do have the correct driver installed for your OS, try swapping your data cable and changing the USB port, if in use. Do not use a USB hub but a direct connection to the computer. Check the device manager to make sure that there are no problems with the hardware drivers. (As above, go to the control panel. Then either in Hardware or System and Security choose the Device Manager. From the Windows key+X, just choose the Device Manager.) Expand the section for the type of port you are using and look for a triangle with a red X or yellow exclamation point. Try updating or uninstalling the driver and then letting the correct driver load when you reboot the computer. (Check with Sony for the driver.)
Next try uninstalling the printer and removing the data cable from your computer. Then install the driver from http://www.usa.canon.com/cusa/support/office/imageclass_copiers/imageclass_d880/imageclass_d880#DriversAndSoftware . Then connect the printer to the computer when prompted to do so. Failure to install the Canon software first can interfere with the installation of the correct driver.
I hope this helps.
Jan 15, 2014 | Computers & Internet
Canon imageCLASS D861 - Windows 7 - 64 bit Is there anyway to update the 32 bit printer to the 64 bit OS?
Unfortunetaly, there is no solution for your problem, Canon did not made drivers for 64-bit OS's.
Alterantively
You can try download Windows XP mod for WIndows 7 or any other virtualization software, and try to install drivers on the virtual PC.
This should work for you.
May 09, 2011 | Canon imageCLASS D880 All-In-One Laser...
My windows 7 system says there is no driver for my canon d880 printer.What can i do?
Log onto there site to upload the program disk.Other wise u need another program disk and printer.
Nov 28, 2010 | Canon imageCLASS D880 All-In-One Laser...
We have a Canon imageClass D860. It came up with the error code E000. We have unplugged several times and left unplugged. When we plug back in, the error message is still there. Have any answers?...
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300/1310,1330,1370,1630,1670, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681/D880
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press Unplug printer and repower it.
Oct 11, 2010 | Canon ImageClass D880 Copier
Can make work when I plug in into my new laptop with Windows 7
Dear Don,
you just have to install driver for your gadget supporting windows 7.....
Jun 16, 2010 | Canon imageCLASS D880 All-In-One Laser...
I have just purchased a dell inspiron with window 7 64 bit and i can't connect the Cannon Imageclass D880
what error is it displaying, plz check weather your printer is windows 7 compatible or not.
Mar 19, 2010 | Canon imageCLASS D880 All-In-One Laser...
I have Windows 7 64 bit and I cannot get my canon image class D861 to work. Microsoft advises to install it on 32 bit - how do I do that with my 64 bit computer?
There is solutions to getting the Canon MF 3111 to work with Windows 7 64bit on this site here: http://www.dragonblogger.com/canon-mf3110-printing-with-windows-7-64-bit/ check the article and comments for help.
Dec 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
WHERE TO FIND A SERVICE MANUAL FOR A IMAGECLASS D880 DICITAL COPIER
http://www.generalmanual.com/Printers/Canon-imageCLASS-D860-D880-Personal-Digital-Copier-Printer.htm
this is the link for your manual please rate my assistance
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Need printer driver for Canon D880 Image Class
Here you go. Just select your OS from the drop down.
Please rate this solution.
Nov 30, 2008 | Canon ImageClass D880 Copier
Canon imageCLASS D880 All-In-One Laser Printer Logo
215 people viewed this question
old marine
old marine
