Question about Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher
Handle coming loose
The handle is coming loose. Can I unscrew the front door panel from the inside to tighten the handle from the inside without causing further problems. It looks like all the electronics are held in by the screws.
  • JERSEYJOEYD May 18, 2008
    Thanks. Perfect fix!!!
    Novelist:
  • 130 Answers
If you only remove the 4(T20 torx) along the flat edge this will only remove the outer door panel. Start from the top and work down. Also if yours has 2 blocks that fall out, they go on the hinge only 1 way.
Posted on May 11, 2008
2007 Yukon Denali GMC inside door handle on driverside is loose and want on the door
Unfortunately, they seem to be making door handles cheaper now and many people are having problems with them. If it is loose, the only thing you can do is unscrew and pry off the inner door panel and once inside the door, tighten up the connections. Try looking at this informative YouTube.com video: https://www.youtube.com/watch?v=pesX5dZeGwo
I hope that helps! :)
Apr 05, 2015 | 2007 GMC Yukon Denali
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Open door handle is loose on a true temp GE stove how do I tighten the handle
You will need to unscrew and unfasten the inside door panel to access the screws that need to be tightened.
Jan 06, 2013 | Ovens
The door handle is coming loose on one side. How can you tighten it down? it looks like you have to take off the front panel to get to the screw to make it tighter. Do you have to unscrew all the screw...
You are correct on this style dishwasher the front panel will need to be removed in order to tighten the handle. Remove the screws around the edge of the door once off the panel will lift up and off.
There will be a bigger screw coming in from the back side, loosen and put a little lock tight on the threads and you will never have to take the dishwasher apart again, that trick works for me..
Have a good evening, I work at the link below to.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Miele 24 in. Incognito G863 SCVi Built-In...
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher Logo
345 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
