Question about Nikon COOLPIX P4 Digital Camera
When i switch my camera on the screen it reads "this card cannot be used" although ive been taking pics today
  • Nikon Master
  • 3,289 Answers
You can have this problem if you are using an SDHC (greater than 2GB capacity) card instead of the identical looking SD (up to 2GB capacity) card. SD stands for "Secure Digital" and SC stands for High Capacity".
You camera has electronics that was designed before the newer SDHC format came to be "mainstream". Using an SDHC card will provide unreliable results at best - or not be usable at all.
Please rate this reply - good luck!
Posted on Sep 02, 2010
Cant take pics,says card protected. used earlier and was fine, now wont take pics at all
Have you checked your memory card to see if it IS in fact protected? It is amazingly easy for some camera memory cards to become accidentally protected.
Check and see if you card has a switch that allows it to be set to read only. And if it does make sure it is not set to read only.
HTH
Jun 11, 2011 | Cameras
I have a FinePix A345 camera and have had it for years. I took pics all day today and then when I went to look at them tonight, my camera read "card not initialized" I can't retrieve or take...
First take the memory card out of the camera. Pictures that have been deleted are probably still there, but will be overwritten if you take any more pictures on top of them.
Your camera is not able to undelete pictures, but there are programs for doing this on a computer. You can put the memory card into a card reader attached to a computer, and use an undelete program to recover the deleted files. Undelete programs are available for free download from the internet, try the one at THIS LINK
If the pictures are very important to you, you might want to seek help from an experienced person.
Nov 26, 2010 | Fuji FinePix A345 Digital Camera
CAN NOT TAKE PIC- PROTECTED CARD READS ON SCREEN
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 12, 2010 | Sanyo VPC-S880 Digital Camera
Although my memory card is 75% full, my screen reads "there are no files"...I am able to display the files on a computer however. When new pix are taken they are stored and can be displayed. I've tried...
Writing to a camera card using a computer will corrupt the card 99% of the time. It will begin to give strange readings (as you have experienced) and will eventually corrupt the camera you try to play it in. I suggest you use a card reader and download your pics to your computer. Then, format the card in the camera to completely erase it and optimize it for the camera.
Aug 17, 2010 | Olympus Stylus / mju 1040 Digital Camera
I have an Easy Share m381 camera and when trying to take a picture the message reads ïnternal Memory Full, I tried a different memory card and the same thing happened, can you help? I tried to...
Your camera won't write to the memory card until you get rid of the pics in the internal memory. Download any you want to save. Then, with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. You should be ok after that. Promise yourself you will never use the internal memory again.
May 29, 2010 | Kodak Easyshare M381 Digital Camera
Not reading the memory card
You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Now, your card should work properly.
Apr 24, 2010 | Kodak Easyshare M753 Digital Camera
I have just got back from holiday where I took 325pics. Earlier today I was able to see them on screen but had not yet downloaded as I was going to take to a store to print out tomorrow. Now when I...
Whatever you do DO NOT FORMAT the card. Take it in to a CAMERA shop, not walmart or drugstore, They can probably remove the card and print from that. Sounds likeyour card is full. They can then put all your pics on a CD and you can then reformat the card and use it again.
Jul 26, 2008 | Cameras
This card cannot be used
Make sure the gold contacts on the card are clean and, as far as possible, that no foreign matter has got onto the corresponding contacts in the camera.
Did you delete the pics when the card was still in the camera or did you take the card out & put it in a reader attached to a PC?
If the former, then I suggest you get yourself a card reader for your PC - they're very cheap now - and use that to copy any remaining pics from the card to the PC.and then format the card in the PC. Then re-format it AGAIN in the camera. If you can't read the card with a PC card reader then you can try to format it (you'll lose any pics on it). If that doesn't work then the card has probably developed a fault. Best to bin it & buy a new one. They're so cheap now it's often not worth wasting time trying to get money back from where you bought the camera.
If the latter and the card cannot be read by the PC then the situation is the same as above. If it can read it then copy all remaining pics from it to the PC then reformat it on the PC. Then try it again in the camera: reformat it in the camera and see if it works. If not then there's a good chance the camera has developed a fault.
Jul 18, 2008 | Nikon Coolpix L11 Digital Camera
My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
Jun 13, 2008 | Nikon Coolpix 2100 Digital Camera
Nikon COOLPIX P4 Digital Camera Logo
137 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
