Question about Imperial ICVD-1-H Turbo-Flow Gas Single Oven
ICV-1 We are a rental company we have a ICV-1 converted to propane thats portable that we rent out to caterers. did not have a lot of luck at the beginning but after some service the oven worked correctly. now the electronic ignition lights and the burners light but when the ignighter goes off the flame goes off. I tried it this am again and it lit but when i came back to check on it 20 min later the burner was off and it was making a loud buzzing sound (like an alarm) that will not go off unless you unplug it.
  • back9bistro Oct 05, 2008
    I have the same type problem. When the unit is first turned on the pilot lights and the burner ignights but the burner then kicks out if you open the door and wait for the fan to kick out and then close the door the burner will ignight again but will go back out. If you turn the fan to low it will light and stay going once to temp, turn the fan back to high and your good to go. do you think this could be the flame switch P/n 1133?
    Scholar:
  • 68 Answers
If you could narrow down the buzzing noise, where and when, it may be significant.
As far as the unit losing its flame, I believe this unit uses a "flame switch" to prove there is a pilot flame. (Part# 1133) So first visually verify the flame quality and the position of the bulb for the flame switch. And assuming that's fine, you need to check the electrical switch portion of the part. It is in the control cabinet towards the bottom. Just two wires.
Usually this problem is a switch failure, rather than a lose connection, or a poor pilot flame. Good luck
Posted on May 30, 2008
Imperial icv-1 electric oven
Not sure what type of oven you are having, Gas or Electric ?
Apr 10, 2014 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
Jan 06, 2012 | Lincoln Conveyor Oven - 1133-000-A
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
How difficult is it to adapt a new kenmore oven from gas to propane?
Hello, W/D here.
It might be even easier than you think! In some areas, propane vendors will convert your stove over for free. If not, they will (the major local companies) have the necessary orifices, and will gladly assist you in making the swap. Try them first, then kick back with a lemonade while they do the work! (I just hope that they WILL do it for you!) If not, like I said, they'll have the materials. I used our local propane company to convert a grill from NatGas to propane, and they had everything I needed, and offered to do it for me. Plenty of free support from them.
Best regards, --W/D--
Feb 23, 2011 | Kenmore Ovens
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
What is the size of the gas intake on the back of the ICV-1
http://www.imperialrange.com/manuals/icvManual.pdf
Go to their web site and check out this manual. On page 3 of "Gas Connections", it says that a 3/4" pipe connection is used.
Hope this helps ya.
Jan 19, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Convert from propane to natural gas
it should have come with different orfices. some for propane and some for nat gas. if not go to any repair shop and they will have them.
Jun 07, 2009 | Imperial ICVD-1-H Turbo-Flow Gas Single...
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Viking range
on the back of each one of the gas valves including the one in the oven there should be an orfice which you can put a 1/2 inch wrench on and turn all the way in until its snug and also flip the cap over on the gas regulator so it shows "LP" this will convert the range to propane let me know how you make out and BE VERY CAREFUL
Sep 11, 2007 | Ovens
Imperial ICVD-1-H Turbo-Flow Gas Single Oven Logo
302 people viewed this question
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
John Rodgers
John Rodgers
Are you an Imperial Oven Expert? Answer questions, earn points and help others
