Indesit wixl143 drum bearing gone - Washing Machines
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
Posted on Jun 23, 2008
  • 100 Answers
SOURCE: Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Posted on Feb 01, 2009
  • 53 Answers
SOURCE: Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Posted on Mar 07, 2009
apart4u
  • 213 Answers
SOURCE: Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
  • 6277 Answers
SOURCE: My Indesit WIXL143 washer has
Sorry, I do not know your particular machine but before considering the ball valve, if it hasn't been done already, I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 04, 2011
Indesit wixl143 broken I try to start a wash it sounds like it should as I can hear water but it's not going into the drum and the door lock light is flashing rapidly along with the extra rinse light
Suggest you take the back off and home in on the water input filter. They are often gunged up with lime scale. Do pull the plug on it before you attack it with a wrench etc.
Jul 02, 2016 | Indesit Washing Machines
My indesit wixl143s, fills with water normally but immediately it drains. washing movements do not start. When manually set to rinse and spin cycles it works.
I would like to know is there any fault code?
Identification of the error code using the 4 LEDs. One or more different combinations of LEDs indicates the failure.
25889772-23mqg50qavgoaobxweiobkxp-5-0.jpg Dado
Oct 02, 2015 | Indesit Washing Machines
I have an Indesit 1400 model WIXL143, washing machine, which is about 3 and a bit years old. It sounds like a tank when its on spin, and makes a grinding noise also. Its also making the washing dirty...
yes probably order them from parts place or eBay but big job to do are you up to it best get quote from indesit probably cheaper new washer
Oct 25, 2017 | Washing Machines
Remove bearing from indesit drum how to split drum
all of the newer indesit washing machines have whats called a welded drum meaning they cannot be split open.the thing about this is to change the bearings you have to buy a full drum. best option is to go through the indesit company themselves. aprox cost £100 if under 5 years and £140 if over 5years. hope this helps
Jun 19, 2011 | Washing Machines
Keeps tripping out my down stairs sockets.checked the wires going to the machine and the plug.all seem fine.? Please help
IS BEARINGS OK IN DRUM IF NOT THE DRUM HAS GONE THROUGH HEATING ELEMENT ...TURN DRUM BY HAND IT SHOULD BE SMOOTH .. OTHERWISE CHANGE HEATING ELEMENT.
Feb 27, 2011 | Indesit W 123 Front Load Washer
The drum is very noisey and is leaking grease on items.
hello sorry to say that it sound like the bearing have gone you can do quick test open the door grab hold of the drum pull up and down if this moves freely then the bearing have gone
regards
shaun
May 28, 2010 | Washing Machines
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Jan 23, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
