I can't get the cartridge door open - Computers & Internet
  • Lebanon Raingam
    Lebanon Raingam Sep 02, 2010
    Let me know your printer's Model. I'll help you with instructions or with a tutorial. Thanks
    Brigadier General:
  • 10,406 Answers
Take the printer to a qualified technician for proper trouble-shooting.
Pick a "small" (owner-operated) computer-store;
if you're lucky, there won't be any charge for resolving your problem.
Posted on Sep 02, 2010
Cartridge install
Press the cartridge-door release button, and then open the cartridge door. Make sure that the door is completely open.Insert cartridge properly inside, close the door...
For more info pl visit you tube link:
https://www.youtube.com/watch?v=vjmKxIqyjWk
Sep 17, 2013 | HP LaserJet P2055d Printer
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I have to get a letter typed and don't know how to open the machine to change the ink????
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Jun 24, 2011 | HP PSC 750 All-In-One InkJet Printer
What does ! in a circle mean on an HP 2035n printer
The printer cartridge door is open. Attention
The print-cartridge door is open. Close the print-cartridge door Attention
Jan 28, 2011 | HP P2035N LaserJet Monochrome Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
''No Cartridge'' Error
check if the cartridge is a hp cartridge
if no use a hp cartridge
if issue stll occurs
remove the cartridge and the papers from the tray
close the cartridge door and turn off the printer
then turn on then printer
you will get a msg install black cartridge
open the cartridge door and put the cartridge inside and the papers in the tray and close the cartridge door
the printer will intiallize and you will get a ready msg on the display of the printer.
if you still get the msg have the printer serviced
Feb 03, 2009 | HP LaserJet 3055 All-In-One Printer
Open to put in new ink cartridge
are you sure you are opening the correct door, mine has different doors and you need to get to the last one, it can be confussing, once you get the correct door the cartridge you will see the cartridge, just flip the top and you can pop it out.
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Door error message
you may have a broken cartridge lock or door sensor. remove all the toner cartridges. then open and close the door and watch for 4 white hooks that open and close on the right interior of the machine where the cartridges are installed. if three of the 4 open and close with door then the one that doesn't is your broken lock. if all 4 work then you have a broken door sensor. Good luck.
Aug 10, 2008 | HP Color LaserJet 2600n Printer
Says printer cartridge access door open when closed
No it will not complain for an open door if there is no cartridge. There will be a separate warning for no cartridge or toner not installed error. You might want to play around with the cartridge door a little and see for a possible paper stuck somewhere inside.
Apr 26, 2007 | HP PSC 2110 All-In-One InkJet Printer
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
