Question about Whirlpool Calypso GVW9959K Top Load Washer
Off balance/loud knocking
The washer makes loud knocking noise at 6 minutes, then at 4 minutes it stops, drains and returns to 6 minutes. It repeats that process over and over. Everything appears level.
  • Anonymous Feb 22, 2009
    Calypso gets to 4 minutes, sounds like it exploded (loud noise) then starts again a 6 minutes. Keeps doing this over and over and over...
  • 975 Answers
Check the inner tub with your hands , if tub is very loose? theres a screw loose or broken at the bottom of center mast, AJ
Posted on May 14, 2008
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
He2 error message f 21
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Kenmore HE2 Plus Front Load Washer
Knocking in washer
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Sal De
