Question about HP Photosmart Premium C309A All-In-One Printer
General printer error 0x6101bec printer will not work on any mode
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: General Printer Error -(0x6101bec)
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Dec 21, 2010
My epson l800 write ,general error, open the printer cover and remove any paper inside the printer .turn the printer off and delete all print jobs ,turn the printer back on.am already try all but still...
Fix Epson Stylus Photo 6 Colors Printer General Error Problem
? 1:02
https://www.youtube.com/watch?v=Ci9MWG7zAkM
Dec 1, 2013 - Uploaded by TechRePair
Fix Epson Stylus Photo 6 Colors Printer General Error Problem. TechRePair ... ???????? Epson L800, T50, P50, R290, R295. User dismantling ...Missing: write
Epson General Error Problem + EPSON Adjustment ...
? 5:05
https://www.youtube.com/watch?v=gaKeB5JJqRc
Sep 28, 2014 - Uploaded by Gigi service
Epson General Error Problem + EPSON Adjustment Program / Waste Ink ... Reset Geral na Epson T30, T33, T50, T1110, L800, XP214, TX133 e ...Missing: write
epson l800 general error ' Error Help
Feb 10, 2015 | Epson L800 - printer - color - ink-jet
Error code 24:08
Hi There,
The most common reason for General Error 24:08;
Hand Feed Mode is ON. (only time this error is shown)
The printer expects the card to be fed from the manual card feed slot at the front of the printer.
If the card is 'manually' fed from the rear of the printer (with the rear card hopper removed), then this error message will be displayed.
Hope this helps,
Kind Regards,
MC.
May 06, 2014 | Magicard Office Equipment & Supplies
Card jam please clear printer
Hi Imran,
I realise you probably resolved this issue a long time ago, but this may help others with the same problem (Card Jam on Rio Pro / Enduro / Enduro+).
Immediately after the Card Jam - Please clear printer mechanism, there should be an error number. All card jam errors begin with 06:??. Most common would be Card Jam 06:05.
This error means that the rear card sensor has detected a card.
However, the card has not past through the sensor. This could indicate a failed card sensor (always on). This may sometimes be caused by static on the cards.
To confirm this, switch to 'Hand Feed Mode' (on the front panel: Menu -> Hand Feed Mode -> ON). Cards are then fed (when requested) from the hand-feed slot on the front of the printer. If the error changes from Card Jam 06:05, to General Error 24:08, this would suggest a faulty rear card sensor (very rare).
Try leaving the printer switched off, and with the DC power disconnected for a few hours. If the problem persists, you should contact Magicard Technical Support.
With Best Regards,
MC.
Apr 09, 2012 | Magicard Rio Card Printer
Will not print, always says error when I press the print button
The process generally involves disconnecting the network cable from your printer, and holding and pressing buttons in a certain combination, usually involving the power button and a cancel button, to reset the factory settings and return the printer to its default mode.
Hope this helps.
Shane
Feb 08, 2011 | Casio EZ Label Printer
  5. Wait 60 seconds.
Dec 21, 2010 | HP Officejet 6500 Wireless All-in-One...
How do empty the 'used toner tank' on the canon multipass F80 printer
Hi
A "CHECK PRINTER" message is a general error warning, only by turning on the Error Management SSW#1 will you obtain an error code number. This may or may not be a waste ink warning, it could also indicate a head tempreture or other error.
Any Authorized Canon Dealer would know how to enter the service mode on this unit and effect repairs
Jan 16, 2010 | Canon MultiPASS F80 All-In-One InkJet...
GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Oct 16, 2009 | Epson Office Equipment & Supplies
Paper was stuck in the calculator. I kept pressing "Feed" to clear the paper. Now the display shows "E" and none of the keys work. I have since then cleared the paper jam. I have turned the computer...
1. Skachati software tools General Tool for its model of the printer (recommend for models i250, i255, i320, i350, i355 to use General Tool i350 this program me never, unlike General Tool i320; for iP1000, iP1500 to use General Tool corresponding to models of the printer).
2. Disconnect the network cord.
3. Holding pressed button of the cut-in ( Power ), connect the network cord, twice press the button Resume (the triangle in кружочке) and release both buttons. The Printer поморгает the green indicator and will fall into service mode (green blazes not blinking).
If after these action instead of constantly burning green printer continues to show the error or you mistakenned in points 2 and 3 (switch off the printer and repeat with point 2), or beside printer additional error, which necessary to avoid, otherwise he will not fall into service mode, but in usual mode unset памперса is not got (that means this error possible hear here).
4. Connect USB cable (if this printer was earlier connected hereto computer then in service mode system is determined his(its) as new device and will install as copy 1 ).
5. Start General Tool.
6. In upper right to corner window program to choose the port of the printer - a window USB PORT (press the arrow in right part окошка and choose from offered; if striking the arrow falls out the started window i.e. General Tool does not find nor one active USB port, that even so come to read the article about памперсах, where is considered to situations, under which General Tool does not work or gives the reports on error).
7. In window of the program, on the left, кликнуть button DEVICE ID . Information must appear On the right on buttons about connected printer (model of the printer and etc) *)
8. In window of the program, on appeared by information, кликнуть button EEP-ROM INFORMATION . Will Appear the new window, in which will is shown information, keeping in memories; check importance D - a condition of the counter (usually more than 100%) and close this okno. *)
*) Points 7 and 8 not obligatory, they serve only for check of correctness of the connection, and can be missed.
The Ithaca, printer it is correct was defined, General Tool his(its) sees and can with him to work.
9. Under window USB PORT small square window EEPROM CLEAR , put the mark in him.
For iP1500 better to throw so: in the centre of the higher part window General Tool is found panel CLEAR WASTE INK COUNTER , under which there is buttons MAIN and PLATEN . Kliknuti on button MAIN (possible at the same time and PLATEN ) and go to point 11.
10. Insert in printer sheet of paper and кликнуть button TEST PATTERN (1 or 2 not it is important). Printer распечатает test page (in process of the print will be a discarded counter памперса) For i320 point 10 conduct two times (i.e. when printer распечатает first sheet, insert in printer else sheet of paper and again кликнуть button TEST PATTERN )
11. Repeat the point 8 (check importance D - a condition of the counter must be 0%).
12. Switch off the printer, disconnect USB cable, close General Tool.
Delete from file Printers and faxes formed in service mode printer copy 1 .
Sep 17, 2009 | Office Equipment & Supplies
Epson printer maintenance 230 General error
General error : head carriage error / chip not recognized. Head carriage can't move freely. Just turn off for about 1 hour, turn on again without ink tank. Plug ink tank.
Jun 12, 2009 | Epson Stylus Photo R300 InkJet Printer
See More http://www.coldreset.com
Dec 20, 2007 | Epson Stylus Photo 1290 InkJet Printer
HP Photosmart Premium C309A  All-In-One Printer Logo
312 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
