Question about THQ Ratatouille PC Games for Windows, Mac
What is COntext Move button? - THQ Ratatouille PC Games for Windows, Mac
How to Screen Capture MS Windows Context Menu?
should be a simple matter of bringing up the context menu and then tapping the "prt sc" button on your keyboard. This will copy contents to windows clipboard. From there you can paste it in "wordpad" or a graphic editor such as "paint" and save it.
Oct 20, 2016 | Computers & Internet
Ansys mechanical : Connections Context Toolbar
im not familiar with that software but try right clicking on the toolbar add buttons ?
or contact the programs customer services.
Jan 25, 2014 | Computers & Internet
How do i down load from an external hard drive
Clic on the file , go to "edit" in the toolbar and select " copy to folder " or " move to folder " .
In Windows Vista or W 7 , if you can't find "edit " , clic on " organize " \ layout " and check
" menu bar " .
Here is another fix :
download and install " copyto moveto " from
http://download.cnet.com/Move-to-Copy-to-Context-Menu/3000-2248_4-10804851.html
Now you can right clic on the file you want to move or copy and find " copy to folder " or move to folder " in the opened panel .
Regards ,
Fanaudi .
Jan 18, 2011 | HP Computers & Internet
Sidebar has suddenly moved to side affecting size of screen. How do I return it to bottom???
You are probably talking about the windows Task bar that normally resides at the bottom of the screen:
Two ways of moving this task ba, to top/bottom/letft/right position of the display:
  1. Move the cursor on a blank/inactive area on the task bar, usually in the largest blank area towards the right, click and hold the right mouse button and drag the Task bar to the bottom of the screen.
  2. Go to the Task Bar 'Properties' (You can get this context menu by clicking the left mouse button after putting the cursor on a blank/inactive area on the task bar) and change the 'Task bar location on screen' option.
Hope it helps: let me know how you go.
Dec 17, 2010 | Toshiba Computers & Internet
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
Unable to update remote Gat a new tv and proggamed it in the software but when I try to update remote I get the message Assertion failed Application-defined or object-defined error (1) Context harmony...
Run the Activity wizard, one at a time, for all of your Activities.
  1. Launch the Logitech Harmony Remote software and login to your account
  2. From the Harmony homepage, select the first Activity listed and click on the Settings button for it
  3. Select Review the settings for this Activity and click on the Next button
  4. Select No, I want to run the setup wizard again to change these settings and click on the Next button
  5. Move through the wizard by clicking on the Next button to move to the next page, ensuring that all questions have been answered correctly. Usually a setting will be unselected, causing the error
  6. Repeat for every Activity in your account, attempting to update each time to check if the error has been corrected
Jan 27, 2010 | Logitech HARMONY 659 Remote Control
Ti-nspire CAS buttons under enter button don't work.
It depends on the context.
The one on the lower side introduces a space. Used with the CTRL key it inserts an underscore.
The one to the right, with a symbol like a linefeed or newline, this one works in the context of matrices.
Used alone it adds a new row to a matrix. Used in conjunction with the CTRL key it inserts a new column in a matrix.
Outside the context of matices it does nothing.
Hope that this helps.
Nov 12, 2009 | Texas Instruments TI-Nspire Graphic...
Context menu continually pops up - mostly when left mouse button is clicked sometimes when keyboard is used. Context menu key doesn't work.
I think the mouse setting is set to left handed and the right clicker is the main clicker and the left is the context menu key. Knowing this, you should follow these steps.
1. Go to "Control Panel"
2. Click "Printers and Other Hardware"
3. Click "Mouse"
4. Go to the "Buttons" tab and switch the setting to right handed
Jan 31, 2009 | Compaq Presario Notebook
How can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
May 15, 2008 | Microsoft Windows Server Standard 2003 for...
THQ Ratatouille PC Games for Windows, Mac Logo
99 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
