Computers & Internet Logo
Posted on Sep 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus labtop with monitor problem,become 80% of his size,please what shoud i do?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Sep 02, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555184
Points
31058
Check that you have not accidentally changed the "screen-resolution".
Right-mouse click anywhere on your Windows "wallpaper".
Click Properties.
Click Settings.
Move the slider to 800-by-600 or 1024-by-768, and then "apply",
and then click 'yes' or 'no', depending on the "good' or "bad" results from "applying" the change.
My hp labtop latitude d600 screen will not work
The problem is caused by one or more capacitors in the power supply that become open, sometimes they have a bulge at the top making it easier to spot.
My asus k52f labtop stopped working without warning. Ive tried to turn it on multiple times but its always gets past the asus logo part then goes black with a little white flashing line. Also the lightbulb...
i have tried numerous solutions for this problem, and they never worked,so what i did was- I got another monitor and hooked it up to my laptop, u can see the everything on the the monitor, so this means ur display hardware is jacked up, or ur monitor is.
3helpful
My labtop cannot start up, lock light on front panel light is on, hard disk is not flashing, screen is black, can you please help?
my labtop will start up the front panel will light and i see will there welcome to Fujitsu
and the screen will be black it will not display . what cause that i want know ...
My problem is my webcam is inverted when i use for cam to cam in my yahoomessenger... please help how to me to sold this problem... thank you...
this is a driver problem but you shoud tell your notebook model you can find it when you put your note book upside down. I have seen this driver issue on asus notebooks but you shoud tell me your notebook model
I have the same problem
Dear! If monitor showes power but not showes display its means that monitor requires heat and it very better if you can give sun-rays. I assure your monitor will work if you do that for 4 hours. Check your monitor sepreatly with another system or computer if it works that means your VGA card not supported so you should change your VGA card but first check your monitor.
Thank You
3helpful
Asus Labtop A4500L Cd Driver
Hello abdu_gabeen,
You should be able to down load all the drives from ASUS support site. Here is the link.
http://support.asus.com/rss/rsshome.aspx
I hope this helps.
Sincerely,
Agent Xiong
Speakers
first check additional speaker to your pc and check sound output
Multicolor Lines on my Sony Vaio Labtop Monitor
Check that the graphics drivers are ok and updated if there are updates as it's a little old know. May also be a screen fault, not worth repairing.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
