Question about Sharp MD-MS702 Personal MiniDisc Player
I have a mini disc sharp md - ms702. i have not played it much in the past few years. now when i play a disc it plays then an disc error appears. it like it can't read the disc. if i listen to the unit you can hear it skiping like when you go to the next song. if i give it a firm tap on the side then it will play for an undertimined time and then another disc error. i have bought and used a cleaner disc. please help.
    Brigadier General:
  • 3,006 Answers
Unfortunately you've done all that you can. The unit is broken and parts are unavailable, even if they were, portable MD players were always fiddly and labour intensive to repair.
It's not all bad news though: as they're obsolete technology there are millions of perfectly good ones lying around unused and unwanted. Every single bit of minidisc equipment which I own has come from my local FreeCycle and Freegle groups, either as a response to an offer or via a request (but note that all such groups usually insist that you must make an offer before you can post a request, but there's no restriction on replying to offers already made).
Posted on Sep 03, 2010
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
Sharp MD MS 702 shows sound is being recorded but on playback shows blank disc, what could be the problem?
That does not sound good. Being optimistic, though, what happens if you record something and then finalize it? Will it play then?
Will it play a previously recorded MD?
Feb 09, 2013 | Sharp MD-MS702 Personal MiniDisc Player
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Can a MDS JE330 play minidiscs recorded by a "hi md" player? most md-players can not.
No. Only Hi-MD players/recorders can play Hi-MD's. They're a later and totally different technical specification. The discs may look superficially similar but it's like trying to play a Blu-Ray disc on a CD player.
Apr 11, 2010 | Sony MDS-JE330 Mini Disc Player
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Sharp MD-MS702 Minidisc recorder - no audio from 3.5 mm output jack...
the solution which seems to have worked for most people is to take the unit apart and make sure that the ribbon cables inside the unit are all attached properly.
Marcus
Apr 30, 2008 | Sharp MD-MS702 Personal MiniDisc Player
Sharp MD-MS702 Personal MiniDisc Player Logo
200 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
