Question about Canon imageRUNNER 3225 Black and White Copier
Black horizontal line on copy - Canon imageRUNNER 3225 Black and White Copier
    Sniper:
  • 66 Answers
Check the **** glass that the paper passes over when you use the document feeder. There could be something on it.
Posted on Sep 02, 2010
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
A black line appears in the copy
if the line on the copy is horizontal(when copy comes out the line should look horizontal) ; change drum cleaning blade. if the line is verticle change the drum.
Dec 28, 2010 | Canon imageRUNNER 400S Copier
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
My copies are coming out with a horizontal black line through the middle of the page. I have a cannon C330D copy machine. And would like to fix this myself if possible. Any suggestions?
If you can wipe off the line with your hand its probably your fuser roller or pressure roller thats need to be changed. IF the line is fused properly and cannot be wiped away you might have a damage drum unit.
Jan 27, 2010 | Office Equipment & Supplies
Black smudge on middle of each copy
defective toner cartridge. Replace it.
Please rate solution :)
May 26, 2009 | Office Equipment & Supplies
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Dirty Copies and Black Line in Middle
the electrostatic drum probubly whent out if it was a cheap copier get a new one if it was expensive have it serviced or replace the drum yourself
Jan 22, 2009 | Canon PC-940 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Canon imageRUNNER 3225 Black and White Copier Logo
115 people viewed this question
old marine
old marine
