Question about Craftsman 26 Hp 54" Deck Yard Tractor
Where do you drain the oil on a kohler 26 hp twin V engine?
I have the same engine on my craftsman. there is a yellow cap on the opposite side from the oil filter. It's located low (for obvious reasons) near the frame. You will need to: remove the cap and connect a hose in order to not create a mess. (the tube was provided with the manuals when purchased) No oil will come out yet at this point. The oil starts to flow when you push in and twist the connector that the hose fits on to.
This was my first experience needing to use a hose to change oil, but it wasn't too bad. Have some paper towels handy though just in case, lol.
Posted on Sep 11, 2010
  • rww777 Jun 12, 2011
    Finally, someone knows what they are talking about. Thanks.
Leaks oil out left side of engine,can not figure where it is leaking from
check valve cover gasket, first clean all oil off engine with brake clean or similar then start it up and look closely around the valve cover on that side
Aug 09, 2015 | Husqvarna LGT2654 54 inch 26 HP Kohler...
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Where is the oil drain plug located? Kohler Pro 23 HP V-Twin engine.
Hi, there is a push and turn plastic drain tap or metal bung directly at the bottom of the dipstick filler neck. Hope this helps, regards Phil
May 06, 2011 | Garden
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman 26 Hp 54" Deck Yard Tractor Logo
680 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
