Casio Parts Cash Register PC Desktop Logo
Posted on Sep 02, 2010
I need to know how I can get a manual, so I can program this Casio CE4630 cash register, bought used didn't come with one?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
181
Points
8
See if this helps ...
http://www.cash-register.org/acatalog/casio_4630er_service_manual.html
  • Anonymous Sep 02, 2010
    this might help
1helpful
Cash button only registers 2p when pressed to open till. till is casio tk 1300 dont know how to re program it to just open.
Try this:
Turn key to program 0 CASH SUBTOTAL Turn key back to REG and try it. -------------------------------------------------------------------------
If anyone needs more information, the Casio TK-1300 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
3answers
Casio tk-7000 scanning and PLU programming
You can add a Hand held Scannerbar with your Casio Tk -7000
Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register:
1. connection to cash register - unscrew and screw back in.
2. connection to scanner, unplug using paper clip into hole and push back in again.
3. rescan default sheet given whe nyou purchased the machine.
4. clean head of scanner.
5. check for cracks on scanner, ie. loss of vacuum.
For MOre Information visit the following sites:
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Regards
Ellin
I have just bought a second hand casio TE-M80 cash register does anyone know how to clear all existing data from its memory
Which data did you need to clear? It might be easier to edit the program so you don't have so much work to do.
If anyone needs a Casio TE-M80 operation / programming manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-M80_users_and_programming_manual.html
Data removal casio TE-100 cash registre
Which data do you need to remove? If you are using it in a new shop, you can just edit the old program. let me know what you need to change.
If anyone needs / looking for a Casio TE-100 cash register manual, c-tech has it here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
2answers
How can i customize the name on casio tk-6000
Turn key to program mode 2 SUBTOTAL 132 SUBTOTAL Now type the new message for the first line of the receipt using the programming sheet (the one with the alphabet) 00 (double zero button) CASH SUBTOTAL
To do the next three lines, just replace the 132 with 232, 332, or 432 and use the same method
For those of you who need / looking for a Casio TK-6000 cash register manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
2helpful
We bought casio pcr-t275 cash register from
Here is a link to the user manual. You will be able to download and save it to your computer, or print it out for future reference.
http://www.casiomobile.com/sa/products/downloads/manuals/PCR-T275_E030624A.pdf
1helpful
Trying to use Casio PCR-T2100 cash register & Metrologic scanner.
for the scanner, u need to program it to suit Casio Cash Register, eg: baud rate, parity , data bit & so on...other wise, the Cash Register cannot receive the signal from the scanner.
After program the scanner , please perform "flag clear" to the cash register.
16helpful
4answers
Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
Top Casio Retail Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
