Question about Belkin Wireless Surf Router (F7D2301)
I am trying to connect to Xbox Live using a Belkin F7D2301 (Surf Wireless) router and am trying to change the mtu size to 1400. I can't find anyway to do it.
    Scholar:
  • 86 Answers
Hi i got your issue I will assit You further......please try with the following steps
Step 1) Connect modem>>Belkin router>>computer
Step 2)Open the browser page
Step 3)Clear everything on the address bar and type http://192.168.2.1
Step 4)Checked towards the left coloumn....under INTERNET WAN click on CONNECTION TYPE-if asking for a password leave it blank and hit SUBMIT
Step 5) Select your connection type as PPPOE and hit NEXT
Step 6) You will get an option to change the MTU SIZE
NOTE: This can be done only if your connection is DSL
Please try with the above steps if you have any issues let me know it
Thanks ......
With regards.....
PRIYA
Posted on Sep 02, 2010
    Brigadier General:
  • 10,406 Answers
Take the inability to "change" the MTU (Maximum Transmission Unit) value as a "hint" that you should not be trying to change it.
Does your XBOX work with the "default" MTU value?
If so, then use that value.
I changed my password and I cant get back on xbox live
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 02, 2012 | Belkin Wireless Surf Router (F7D2301)
Xbox live
Some modem have built in router.So in my case i have hughesnet hn 9000 modem so what i did is connect my modem to a switch and from your switch connect to your xbox live. so buy a switch.
Feb 14, 2010 | Belkin (F5D7230-4) Router (587009)
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Issues with my Belkin F5D8635-4v1 connecting to xbox; it says the MTU settings are wrong on the router but i have checked and changed but still it will not work...any idea's? - I have checked all TCP / UDP...
MTU settings are set independantly of other network protocols.
Google MTU ~ xbox ~ and your specific use to find an ideal value to set your MTU to which may well differ from documentation you may have about your device/requirement.
Dec 30, 2009 | Belkin N1 Vision Router
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
Cant connect to xbox live...says that my mtu settings are too low
It's not up yet . Do you know of anyone else on it already? I think it's still being fixed.
Jun 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Unalbe to connect ot x box live
Have you verified that on the router end of things?
On your computer, open up your browser and type in "192.168.1.1" on the address bar (where you type websites)
Next it will prompt you for a username and password. By default leave the username blank, and enter "admin" as the password.
When the page loads you will see a tab that says "Setup", click that. You will a setting that says MTU, change that to "Manual" and set the size to 1400, then hit "Save Settings"
After that unplug and re-plug your router (give about 20 seconds in between) and restart your XBOX. You should be good to go. If that does not work try to bypass the router and connect it directly to the modem to see if you have the same issue
Feb 25, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Slow Internet using Belkin Wireles G Plus MIMO
Try setting the MTU size to 1400 and also check if there's any firmware update for it if there is update the firmware.
Hope it help
Apr 22, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless Surf Router (F7D2301) Logo
949 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
