Question about InFocus ScreenPlay 4805 Multimedia Projector
INFOCUS Screenplay LCD projector...
We are having trouble adjusting the keystone on our projector. The picture hangs off the bottom on the left and just slightly on the top on the right. Seems square top left and bottom right. Every adjustment we make seems to not work. Any suggestions? (Not sure it is a 4805, but is a ScreenPlay)
  • 563 Answers
Hi there
I take it the Projector is ceiling mounted ?
If this is the case check that it is installed with the lens of the Projector in the facing straight to the middle of the screen or try adjusting the bracket's swivel head to move it a bit - should do the trick !
Posted on May 13, 2008
I have just replace the bulb and it works fine but in the lower corner of screen there is a message to replace bulb how do i clear this out ?
if I remember right, hold the 2 keystone buttons in and while you are holding them in, switch the projector on and continue holding the keystone in for 20-30 secs.
Jun 28, 2010 | InFocus ScreenPlay 5700 Multimedia...
No picture and a red blinking light. no output from projector
reset the lamp hrs. do this by holding in the 2 keystone buttons then switching the unit on. keep the buttons pushed in for 30 seconds. if this doesn't work, replace the lamp.
Apr 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
Picture colour is wrong. Too much green and pink.
first reset the settings to factory default. then swap out the cable. if you still have trouble, replace the colorwheel.
Mar 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Once the projector is plugged in there is no picture. The projector comes on but the lens doesnt open
Try doing a manual reset by depressing the two Keystone buttons and turn power on. Hold down the two keystone buttons for 15 seconds, then release and turn projector OFF.
Turn ON projector and it will be reset.
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Slanted Border- Projector image is not square
Is the image slanted on the bottom as well?
Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus projector
The settings of the video section of the computer probably need to be adjusted; this is a synchronization problem.
Check the Infocus website for clues.
http://www.infocus.com/Support.aspx
May 27, 2008 | InFocus ScreenPlay 7205 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
104 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
