Question about Remington SCC100R
Can wash clipper to clean? - Remington SCC100R
  • Remington Master
  • 1,625 Answers
The blades are washable. For item information and video see link below from shaveroutlet.com
http://shaveroutlet.com/remington-scc100-rechargeable-short-cut-clipper-kit-p-812.html
Posted on Sep 04, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Problems Andis AGC 2
Sounds like it's time to replace the clippers with something much better.
Apr 24, 2013 | Andis Agc Super 2-speed Clipper...
I was shaving my dog using oster ultra cordless clipper, and suddenly the clipper is not cutting hair instead it grabs hair. I opened it and clean out hair under blade, but unfortunately, i did not help.
With most clippers, after an amount of use they need to be cleaned then oiled. Most sets come with some amount of oil for your clippers. Otherwise you can purchase it separately. This should fix the problem.
Aug 25, 2011 | Oster Health & Beauty
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
I purchased a pair of Forfex Magnetic Motor Clippers (FX684XW), sku #763358 and a mini-trimmer clipper (FX785NW) had them for about 3 months. I have had nothing but problems with them. They have pulled...
Have you tried removing the 2 screws holding the comb plate down against the moving blade?
Often cut hair residue will build up under the comb plate to the point where the blade does not cut properly and even seizes against this plate.
Just remove the screws, the comb plate and the cutting blade, clean everything thoroughly with some rubbing alcohol. Make sure to scoop / vacuum out any hair that hair that has fallen into the clipper body through the hole under the blade.
Once the parts are cleaned, reassemble the unit and apply a liberal coat of light mineral oil (available at any drug store) to the blade and to the underside of the comb plate. Don't be stingy, you can always wipe off the excess later before using it.
Now screw down the the comb plate onto the blade and body and tighten the screws just enough that it holds the plate securely but doesn't bind the blades in place.
Turn on the clippers and check that they reciprocate properly. Turn off clippers and adjust the tightness of the screws as required. If the clippers don't start when you switch them on then you probably have the screws too tight.
Now turn on the clippers and hold them blade end down over the sink and pour some mineral oil (at least a spoonful or two) directly on the blade / plate interface so the oil washes over and under the moving blade and in between the blade and the plate. Do this while the clippers are running, there will be a little spatter but that's why you are doing it over the sink.
You can do this oil wash every few haircuts cuts if you like, it's just an easy way to wash out the tiny hair particles and keep the blade well lubricated at the same time. Just wipe off the excess with a paper towel and its good to go. Hope this works for you and helps out a bit.
Please comment back here to this page if you have any questions or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Feb 23, 2011 | Forfex FX 690
Trimming with #10 blade seems to work ok but #7 blade will grab the hair and will not cut clean. I've purchase another new #7 blade to see if the blade is the problem but the same result. Any ideas? Thanks...
I have the same clipper and have found that if you comb,wash and dry the hair thoroughly first, it works alot better! Also putting a drop or two of the oil on the outer edges of the clipper. (did you get a dvd with it?)
Apr 19, 2010 | Andis Advanced 21490 MBG2 Hair Trimmer
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Cleaning Oster 78004-011 Clippers and blades
OK compressed air is perfect for your clipper, thats all it needs! Take the filters off (at the bottome of the clipper, either side of the cable) periodically and clear from excess fur. Replace. As far as the blades are concerened, Brush the excess furr off with a toothbrush or similar. Slide the cutter (smaller of the 2 blades) to one side (past half way but not all the way off!) clean exposed teeth on both blades with a bit of oil and a toothbrush, push the cutter the other way and repeat. Blade wash's tend to rust the blades, you need a big pot of WD-40. Get a 5 litre tub from the internet, only thing is there, postage will be a killer. I work for a clipper repair, blade sharpening company and we have it delivered by the truckload! Do what you do with the blade wash, but do it in WD-40. Wipe off excess afterwards and dont soak the clipper in any liquid because of electrc shock.
Thats all you can do! When your blades go blunt or clipper needs service repair: www.sheareaseltd.com If I have helped you please tell your friends about our website! Thank you!
Feb 25, 2009 | Oster Golden A5 2-Speed Universal Motor...
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Remington SCC100R Logo
184 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
