Question about Aurora Electronics AS662C Shredder
Jammed in Auto, but works fine in reverse. How to unjam?
    Problem Solver:
  • 10 Answers
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Posted on Sep 02, 2010
Staples jammed.How can I unjam and open it?
Hi Alan:
You don't specify what make it is, or if it is powered.
If air, disconnect from supply, remove any staples from magazine, and attempt to discharge.
There will be allen head screws holding the firing mechanism assembly together. Always treat it as if it could discharge.
Carefully loosen the screws and try to remove the jammed staples with a small screwdriver. You may need to actually dis-assemble it to get it unjammed.
Clean parts, oil, and re-assemble.
Should be fine.
Feb 09, 2016 | Staples Tools & Hardware - Others
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
How can I unjam?
There should be a reverse position on the of/off switch
Jul 26, 2014 | Identity Office Equipment & Supplies
My as1200x will only go on in reverse, which makes it hard to load.
Unplug the power cord because that happens when underneath the paper is all jammed. It will not go forward until you unjam the stuff on the other side. It happened several time with shredding to much paper at one time.
Apr 29, 2014 | Office Equipment & Supplies
Rexel shredder
Spray with WD-40 or similar lubricant/release agent and let it soak for a while, the remove anything that's jamming the sensor with tweezers and switch the unit on and keep cycling between auto and reverse for a minute or two until unit gets unjammed. Then to reduce friction and to protect the blades use some oil in the feed opening, especially after using WD-40 Good luck
Oct 01, 2013 | Office Equipment & Supplies
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Jammed P48C
Try soaking the clog with dish detergent and hot water (seriously !) overnight. Soap dissolves paper.
Oil with 3-in-1 oil generously.
Dec 31, 2009 | Office Equipment & Supplies
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Aurora Electronics AS662C Shredder Logo
407 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
