Question about HP Compaq Presario V2000 Notebook
Computer connected to internet through wireless but browsers don't work
My computer is connected through a wireless connection with an "Excellent" signal at 54 mbps. When I try to use IE or Firefox they both say that they are unable to load the page. I've tried repairing the connection, restarting, leaving it off for awhile, renewing my IP address, and when I run the diagnostics through IE is says there may be a problem with my "Winsock" but when I let IE restart the computer to fix the issue it still doesn't work. I don't know what else to do!
    President:
  • 1,944 Answers
Here are two links that explain what you need to do:
http://windowsxp.mvps.org/winsock.htm
http://support.microsoft.com/kb/811259
or you can simply use this tool:
http://www.snapfiles.com/get/winsockxpfix.html
Posted on May 10, 2008
DIR-815 Signal strength excellent but no internet
Possibly the power outage caused your modem to reset. The wired connection would still work. first thing I would try is to reset the modem with the reset button, login to the management console and put in your network name and password again.
Dec 21, 2017 | ASI Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Cant connect to wireless internet. Diagnosis tells me i am not plugged in. The wireless reception is excellent. When i connect my laptop direct to my wireless hub it works but without connection to hub no....
logon your ROUTER BY ENTERING IP IN BROWSER WITH ADMIN CREDENTIALS
OR IF YOU FORGOT PASSWORD THEN RESET IT BY RESET SWITCH TO FACTORY DEFAULTS
WHICH IS ON BACK SIDE OF ROUTER THEN CHANGE SETTING --SSID --WEP KEY
PUT A NEW KEY AND RECONNECT YOUR LAPTOP
Feb 05, 2011 | Dell Latitude D600 Laptop Computer -...
Hi, I have an Hp computer with an AMD processor 802.11, and my problem is that i cannot connect to the internet using my wireless router. I have done everything from disabling to enabling my wireless...
ok, if the computer see's the router and connects then the problem is most likely in your browser settings. Check under options in either browser and see what your default connection is. Change that to your wireless and make sure you LAN settings are set to auto detect. You also want to check you router settings. If it has settings for what channel it broadcast your wirelss on make sure it is NOT using channel 6. I had this problem with my HP's, all 4 of them. Once I chenged it from forced 105mbs and to use channel 10 all the computers worked. I don't know why it is a problem but HP's don't like channel 6 on wireless routers.
Oct 15, 2009 | HP Pavilion dv2000t Notebook
Trouble with Linksys Wireless Router
Try unplugging both the modem and the router. count to 15 then plug back in and try.
Keep in mind also that some routers dont connect 100% till you open a browser, weird but I have had similar problems.
It sounds like you may have problems at both ends.
Several things come to my mind;
make sure you shut down ALL programs in the background.
you are trying to problem solve by elimination, so close anything that may connect to the internet and take away that variable.
scan for spyware etc.
do a registry clean, temp files cleanup etc.
sometimes restarting the pc can help
good luck
haydenshaw3
Dec 28, 2008 | D-Link Wireless
Second computer can't connect to the internet
I had a similar problem when I got my laptop. What I did was type 192.168.2.1 (yours might be different because we have a wifi router plugged into a normal router, so try 192.168.0.1 otherwise) into the internet URL address box. This takes me to the Wireless Router's domain page. I then click on 'Wireless' and then it asks me for a password, which I leave blank because I never set one up, and now I am in the Wireless settings menu. I then click 'Use as Access Point' and then 'Enable'. Then I close the browser.
I then check my Wireless connections on the laptop and can see the router there in the list. I double click this and also make sure the 'Automatically connect to this network' is enabled. I wait a few seconds for it to detect and connect.. "Local and Internet Access"!
I open the internet browser and I am on my Google homepage.
Your settings will be slightly different, but essentially the same.
Try that.
Good Luck!
Chris (ziraffa)
Dec 26, 2008 | Linksys Wireless-G WRT54G Router
Internet connection
i don;t realy understand ...
so u have a wireless router and the computer that connects to it shows that is connected but it doesn't work on the internet ?
than the computer connecting to the router is connected, but the router it self is not connected to the internet ! Go at the router settings and configure the internet connection ...
if this is not the issue, please try to explain again with more details what the problem is....
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Latitude d600
the excellent connection refers to the wireless signal and not the internet connection, so go to tools on your web browser, internet options, then delete all temp files, history and cookies, close your browser down and open it up again and see if it connects, if not keep clicking refresh.
Try different sites incase there is a fault on the site you are trying to browse.
Nov 09, 2007 | Dell Latitude D600 Notebook
HP Compaq Presario V2000 Notebook Logo
335 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
