Question about Dell Precision M70 Notebook
How to break bios password for dell precision m70 laptop
    Brigadier General:
  • 10,406 Answers
The password exists to prevent a THIEF, in possession of your laptop, from "breaking-in" to the stolen laptop.
As such, find the original bill-of-sale, to prove your ownership, and contact Dell's Technical Support, and get them to assist you.
Posted on Sep 02, 2010
  • 480 Answers
The only way for you to remove BIOS password is to remove the CMOS battery inside the laptop. You can go to support dot dell dot com.
Cheers!!
2 Suggested Answers
sim4182
  • 393 Answers
SOURCE: how do I reset my
open ram cover u will see the small jumer gold color just short it with flat screw driver .. thanks
Posted on Sep 17, 2010
Dell precision m70 administrative password is is locked. ehat can i do
Use a program called Kon-Boot
it will bypass all Windows security altogether
Apr 16, 2013 | Dell Precision M70 Notebook
I have acquired a Precision M70 that doesn't post.
that is correct
try this
remove battery completely and run on adapter only
press F8 for safe mode when powering up
report what you find
May 28, 2012 | Dell Precision M70 Notebook
How do I reset my lost bios password for Dell Precision M70 laptop
Sep 17, 2010 | Dell Precision M70 Notebook
Dell D420 Bios Password
I got my Dell Bios & HDD Master Pasword within a few minutes from http://www.bios-password.kickme.to/
Jul 20, 2010 | Dell Latitude D420 Notebook
How can you reset a Precision M70 Laptop bios password
For that you need to reset bios password.
There is 2 way (1) Reset bios password with cmos cell and jumper settings.For that you need to open back cover of laptop then find motherboard pull cmos cell from motherboard for 10 minutes then reattach it into it's position.There jumper near cmos cell named clear_cmos it has 3 pins 1-2-3 put jumper in 2-3 position then power up then again put it into it;s original position 1-2 then all password RESET.
(2) you can RESET bios password with software download it from below link.
Click here
Click on above link download software there is instruction how to reset bios password.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Dell Precision M70 Notebook
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
Resetear bios
Si se ha olvidado la contraseña del BIOS, you' necesidad del ll de entrar en contacto con el soporte técnico en Dell para resolver la contraseña
Jun 08, 2009 | Dell Precision M70 Notebook
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Dell Precision M70 Notebook Logo
271 people viewed this question
Alun Cox
