Question about Sanyo DP32746 32 in. LCD Television
Sanyo ce32ld81-b when picture bright screen flickers this starts after it's been on for 20 mins or so
4 Suggested Answers
SOURCE: Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Posted on May 01, 2009
SOURCE: sanyo lcd tv flat
I have researched this problem and it is so common we that own this piece of junk ought to form a class action suit and sue. It is caused by a bad part or bad connections to a part called a backlight inverter. It seems the LCD needs a higher voltage than supplied by the 12vdc power pack so this part re-chops the DC voltage to generate the LCD requirement.
The date of manufacture is on the back of these TVs and all the problems seem to be from those made in 2006 to 2008
Posted on May 05, 2009
  • 3 Answers
SOURCE: how do i turn on
turn on at the rear (switch next to power lead socket) and the blue standby light on the front should illuminate. on the right hand side of the tv is a series of buttons, press the top one to start the tv, the others are channel up & down ,volume up & down. If you have a Sky remote you can programme that to run your TV
Posted on Oct 26, 2010
My sanyo tv model num CE32LD81-B 32in LCD TV powers up but only as a blue screen
You likely have a bad tuner board. Check that the power board and tuner has any blown caps and replace if needed.
Aug 26, 2014 | Sanyo Televison & Video
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
46" LCD HD TV no picture until 20 min after being
Check the video module see if you can resolder the components, the tv have some loose connection in that video section and in the power supply.good luck.
Oct 04, 2011 | Sanyo 42 in. LCD TV
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
Nov 24, 2009 | Nokia N95 Cellular Phone
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Feb 25, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Sanyo DP32746 32 in. LCD Television Logo
103 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
