Question about Panasonic PT-65WX51 65" Rear Projection Television
Resistors and capacitors
What do the resistors look like are they green with round brown lines round them are the capacitors the orange round ones ive noticed some are black on the top also where on the pcb board is the flyback auto transistor and the horizontal amplifier thanks
    President:
  • 2,712 Answers
Resistors are usually cylindrical, depressed in the middle and have three coloured rings (sometimes 4) around it to show the resistance value (but they do come in other shapes as well). The leads are generally on the base, one on each end. They are usually placed length-wise on the board. Here is a sample pic:
Capacitors, on the other had, are usually cylindrical all the way through and are encircled by a plastic sheath. Sometimes they look like small rectangualr compressed boxes.The leads are usually both at the base end on one end only. The top or cap is usually visible and point upwards from the board. They have their values usually printed on the plastic sheathing.
Here's a sample pic or two:
Here is a LINK that will give you more info, if you wish.
Hope that helps, and dont forget a Fixya rating!
Cheers,
IrishDruid.
Posted on May 10, 2008
Colourcode. resistersr512andr514. forPacificsubwooferhcs101circuitboard
Resistor color code is as follows:
Black-0/.0
Brown-1/0
Red-2/00
Orange-3/000
Yellow-4/0000
Green-5/00000
Blue-6/000000
Violet-7/0000000
Grey-8/00000000
White-9/000000000
The first and second color corresponds to the numbers .0-9
The 3rd color corresponds to the zero(s).
So, 512 would be: Green/Brown/Red (5100 ohms)
and 514 would be: Green/Brown/Yellow (510000 Ohms).
Feb 09, 2017 | Computers & Internet
I have a 1997 Tahoe wont start but turns over
first check with your GM dealership ,they have recall on ignition key ,based on your vin# you may get lucky,
but if not here what you star with
there is a resistor in your key(people call it chip,but it is nothing but a resistor to complete the circuit) clean both side with alcohol wipe,also check make sure there are resistance from one side to other,if it is open you need new key
here are values,yours are one of these
Resistor Values:
  • 392: Orange, White, Red Black
  • 523: Green, Red, Orange, Black
  • 681: Blue, Gray, Brown, Black
  • 887: Gray, Gray, Violet Black
  • 1,130: Brown, Brown, Orange, Brown
  • 1,470: Brown, Yellow, Violet, Brown
  • 1,870: Brown, Gray, Violet, Brown
  • 2,370: Red, Orange, Violet, Brown
  • 3,010: Orange, Black, Brown, Brown
  • 3,740: Orange, Violet, Yellow, Brown
  • 4,750: Yellow, Violet, Green, Brown
  • 6,040: Blue, Black, Yellow, Brown
  • 7,500: Violet, Green, Black, Brown
  • 9,530: White, Green, Orange, Brown
  • 11,800: Brown, Brown, Gray, Red
next take the fuel pump relay out and check it
Check the fuel pump relay first, take it out and check the pins. If they are discolored at all, I would replace it. You can clean up those pins and try it, and make sure the female spring clips are tight too.
There is a hot wire straight to the pump but it's usually a real PITA to find. It's in the big harness leaving the under hood fuses, running under the brake booster.
next you check fuel pressure make sure,pump is working correctly
with key on/engine off should read 60 to 65 psi,with engine running about 55,next as engine running take the vacuum line off the fuel pressure regulator,and pressure should go up to 60 to 65,if not regulator is bad,also check inside the vacuum line and regulator if it is wet or gas present that means diaphragm in regulator is ruptured ,it is also bad,need to be changed,BUT BEFORE CHANGING PUMP.CHANGE THE FILTER ,SEE IF THAT BRING BACK THE PRESSURE UP, if all good then you need to check for spark
let me know and I can help you more
Apr 06, 2015 | 1997 Chevrolet Tahoe
AC condenser motor 3 wires, black,orange,brown. Which is L1, L2 and capacitor ????
The black wire is usually the L1 line connection. The brown wire is usually the capacitor wire, and that leaves the orange wire for the other line connection - either L2 or Common depending on the voltage involved.
Aug 14, 2013 | Emerson Fan Motor & Blade - 1/6 HP
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
TV AC adapter gone bad
I just repaired one with the same model number. The 10 meg ohm resister isn't the problem because it's from the line in to the metal of the heat sink or something like that and any 10 meg ohm will work. The problem is no output of 13 volts. In my case the "cure" was replace the two 560mfd @35 volts capacitors mounted on the other end (opposite the power in cord) they were both open and there was a black oil like leakage from them on the p w board underneath them. You will have to remove the metal that almost hides them. Unsolder the transistors mounted on it and remove it as an assembly. Be sure to clean it up with lacquer thinner and observe the polarity of the capacitors.
PS I have been repairing TV for more then 50 years and I don't no what the green stripe is for either but it isn't of any importance in this case.
Kirk's TV Evart MI
Sep 03, 2008 | Televison & Video
RESISTORS
the baby blue ones with the lines Blue,Gray, Gold ,and gold are the 6.8 ohm resistors the other resistors with the lines blue,orange,brown and gold are 630 ohm , Yes if those resistors are open even one of them the set will not converge. A digital ohm meter is more accurate, but you have to remove one side of the resistor to check them and if theyre open they wont read anything. If you leave them in circuit even a open resistor can measure good due to the resistance in the circuit. Removing 1 leg out of circuit then checking will spot an open resistor quickly.
Apr 04, 2008 | Philips 55PP9352 55" Projection Television
Ntl phone wiring
The blue and blue/white attach to the red and green wires behind the jack assembly. The other colors are only used for a 2nd and 3rd line number. Thank You Jerry
Feb 10, 2008 | Lands Phones
Toshiba projection tv
there is no pink in resister codes
red or orange i think it's orange
32 X 8 or 5 32000 32K? most are low resistance
3.9 ohms and below.
Dec 06, 2007 | Toshiba 43HX70 43" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
