I have a old kenwood stereo hifi stack system and ive lost the instruction manual to set it up please can you help, amplifer A76,tuner T76L,turntable p58, graphic equalizer GE760,cd player DP76 and cassette deck x76
  • 319 Answers
SOURCE: connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
Posted on May 30, 2008
tech48
  • 624 Answers
SOURCE: i have a 1987 model
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Posted on Sep 27, 2008
dunnbiker
  • 8546 Answers
SOURCE: Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Posted on Jan 27, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
Posted on May 17, 2010
caroldon
  • 17130 Answers
SOURCE: HELP NEEDED I am having trouble
In the first part use the following leads
1. Keep the Power amp as the base and connect to the Cd input the CD player, the tuner to the tuner input, the cassette deck - play output to the tape in ( amp) and Rec out of tape to the tape out(amp).
connect all the RCA sockets with the R&L in the same side of the input/output.
Now the graphic equaliser input must be connected to the Amplifier's preamp output and the equaliser's output must be connected to the Amplifier's preamp input.
Now the equaliser will work through the amp.
The left and right speakers can be connected accordingly with the polarity in order.
The second system can be connected similarily with the cassette deck, tuner and cd player connected to the input of the Amplifier using the R&L RCA sockets.
Connect the speakers accordingly and test.
Please connect each RCA cord one by one and do not mix them up.
Posted on Aug 28, 2010
We just installed the Kenwood KDC-X692 in our 1993 BMW 740il. The tuner works, but the CD has no sound and the AUX doesn't work either. I'm also confused on the bluetooth ready but lack of instructions...
i'm assuming you are going through an amplifier. if so it sounds like you are using the blue wire instead of the blue/white wire to turn the amplifier on. i can't really help you with the bluetooth though.
Jan 05, 2011 | Kenwood KDC-X692 Car CD/ MP3 Player
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Hi, I'm unable to set the time on the clock, i'd appreciate it if someone could help me please
detailed instructions depend on the model of your Kenwood stereo.
Please use one of the links below to download the complete user manual reporting clock setting instructions.
Kenwood Electronics | Download > Instruction Manuals
Kenwood Corporation|Manual Download
Jul 16, 2010 | Kenwood Car Audio & Video
Kenwood Stereo
Jan 26, 2010 | Audio Players & Recorders
I have an old kenwood shelf system, with the following components:kenwood stereo power amplifier B-A9 100v 125w, kenwood C-A9 digital pre-amplifier/tuner, kenwood stereo cassette deck x-A9 plus a cd...
Thanks for your concern. I was badly in need of a manual and luckily enough I got across a friend who had one in Uganda. So that solved my problem.
Jan 01, 2010 | Kenwood XD-A55 CD Shelf System
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Kenwood stereo synthesizer tuner t-85l
T-85L is a component of a hifi system not suposed to work alone. You have to connect it to another Kenwood component (an amplifier like the A85 ) through a special cable to power it on/off. The special cable can be used point to point or as daisy-chained.
Nov 05, 2008 | Yamaha HTR-5830 Receiver
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
Kenwood stereo intergrated amplifier a-76
The only tricks to power up again are this:
Amp to Equalizer : Use the "Connector " of the Amplifier - IN and OUT and connect them to the Line IN and Line Out of the equalizer;
All modules: Use the system control cable like in serie, for example the lowest connects to the above and from thsi one to the other above and so on;
Regarding Power: both CD, Deck and Tunner have different colors to connect to the Amplifier power source, you can't miss it;
Audio Cables, just follow the IN and OUT with correct colors and you are done!
Rgds,
TrepaTrepa
Feb 21, 2008 | Audio Players & Recorders
284 people viewed this question
 Grubhead
Grubhead
