Question about Samsung MW1080STA Microwave Oven
Is it safe to use a microwave that has peeling paint/rust under the bottom of the turntable?
5 Suggested Answers
  • 38 Answers
SOURCE: microwave oven
THERE IS SPECIAL MWAVE CAVITY SPRAY .MAKE SURE YOU SANDPAPER IT THEN USE NORMAL PRIMA ALLOW TO DRY USE FINE SANDPAPER JUST TO MAKE SURFACE RIGID THE SPRAY
Posted on May 09, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: rust under turntable of microwave can i paint it?
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jun 02, 2009
kalamazoo222
  • 285 Answers
SOURCE: I have a sansung microwave. Is it harmful to use
The paint plays no role in protecting you from the microwaves. The metal case is what contains the radiation, so you should be just fine.
Posted on Dec 03, 2010
  • 6771 Answers
SOURCE: I have a samsung microwave.
This is a special white enamel paint that is very hard to find, I don't have any personally but the manufacture use to supply the paint to people like myself to do touch up repairs. The only thing I can suggest is hound Samsung for the microwave paint because the magnetron will eventually short out making the oven useless.
Posted on Jan 27, 2011
Paint is peeling off how can I fix it and do you know if its dangerous
I wouldn't advise trying to fix it and it's not dangerous. When heating food it causes condensation on the inside of the oven which pools at the bottom and causes rust and paint peel.
Oct 11, 2012 | Microwave Ovens
My microwave inside bottom paint is peeling off. I would like to know if there is special paint that cam be use safely to fix it. PD. It is not a matter of buying a new one. Is the challenge of fixing...
You can only use appliance paint which can be bought from the local home improvement store.
The exact instructions will vary from brand to brand and type of paint application used but you can follow these general steps:
  1. Clean the appliance thoroughly with soap and water and leave to dry.
  2. Apply a treatment on rust spots to prevent the rust from spreading or showing up through the new paint.
  3. Unplug and move the appliance to a well-ventilated area or create good air circulation in the painting area.
  4. Remove or protect areas (such as handles and other decorative details) on the appliance that should not be painted.
  5. Paint the appliance according to the product instructions.
  6. Let dry thoroughly before moving.
  7. Apply a second coat if necessary.
May 17, 2011 | Microwave Ovens
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Chipping/peeling rusting paint in interior under carousel
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 11, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Hello i have a problem with my microwave I used an abrasive cleaner on bottom of microwave under the turntable it has now started to rust at this stage surface rust only is it repairable
Yes you can, it is a painted surface correct? If so buy some rust inhibitor spay or primer and spary the bottom and then paint. Make sure you tape off any vents on the bottom before you do anything
Oct 01, 2009 | Microwave Ovens
Rust under turntable of microwave can i paint it?
Jun 01, 2009 | Sharp R-820B Convection/Microwave Oven
I have a Kenmore microwave oven and the paint under the turntable is peeling. Is this harmful? Is there a fix or paint that I can use to correct the unsightliness of it?
You should re-paint it using microwave touch-up paint.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2009 | Kenmore 62702 Microwave Oven
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Paint has chipped off bottom of MW
Moisture accumulation can sometimes be caused if the cooling fan is not running properly or if the vents in the back are blocked or there is not enough free space around the sides and back of the microwave.
One thing that helps is to keep the door open a few minutes after using it and to wipe down the inside after use.
Nov 22, 2008 | Panasonic NN-T990SA Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MW1080STA Microwave Oven Logo
146 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
