Question about Maytag MGT3800T Top Load Stacked Washer / Dryer
WATER IS NOT DRAINING. CHECKED HOSE, PUMP, BELT, ETC. WANT TO SEE IF PLUGGED WITH CLOTHES AROUND DRUM BUT AM HAVING TROUBLE GETTING LID OFF. PUSHED IN LOCKS WITH PUTTY KNIFE AND STILL LID WILL NOT LIFT.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 03, 2010
Our frigidaire front loader washing machine does not spin and the clothes are still wet! Model FTF1240FS2. It seems to go through the cycle and pump the water but the drum will not spin. I checked the...
heatman101
Mar 05, 2011 | Washing Machines
My front loader washing machine is not draining the water after the cycle. it is still full of water and the clothes are still soaking wet.
Hi..
If your machine does not drain you need to check this
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Before testing the lid switch, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
Regards
PCmania
Aug 27, 2009 | Washing Machines
GE WPGT9350 won't drain
Hi...
You need to check this parts.
Test the lid switch(some models)
Inspect the driver belt(belt drive only)
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope it will help you.
Regards
ICmanServer
Aug 09, 2009 | GE Profile WPRE6100G Top Load Washer
Don't spin
Hi...
Regards
ICmanServer
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
FTW445ges2 Washer won't drain, buzzes during drain cycle
Hi...
Regards
ICmanServer
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
BOSCH washdryer WVF2402GB/02 - not spinning clothes
Remove the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running. Good luck :)
candogan62
May 07, 2009 | Bosch Classixx WVF 2402 Front Load...
Draining
Hi There,
Have you checked the Pump Belt?
Mar 30, 2009 | Roper RAS8445KQ Top Load Washer
Hotpoint wma12 not draining help please my work clothes are stuck
You need to check the pump filter which is accessed by removing lower rear panel of washer.
On the right you will see a large black hose, ondo securing clip and remove hose, be careful because there will still be water in it.
Better still , lay hose down into a bowl or similar to drain any remaining water in m/c.
Inside you will see the plastic filter, remove and clean, refit filter and hose, make sure you get it on properly
Test it for leaks, and that should be it.
If it still does not drain then you need to check the pump is o/k.
You can do this by listening or feeling if you can hear the pump going.
BE CAREFUL
Any more info , let me know.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint First Edition FEW12 Front Load...
Washer will not spin out after wash
Is the water draining out of the machine? Is the drip dry option selected? If the water is not draining out, check drain hose and drain pump. Is the lid switch operating?
Oct 31, 2007 | GE WBSR3140DW Top Load Washer
Maytag MGT3800T Top Load Stacked Washer / Dryer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
