Question about Refrigerators
My frezer is running warm and the My freezer is running warm and the ice maker is not working, I can’t get water to come out of the door. The refrigerator is running fine. MSD2657HEW
  • 770 Answers
I need you check a few things >>> is the freezer fan running is the back wall of the freezer have a heavy frost? are the condenser coils clean ..do you hear the compresser and fan motor running in the back of the unit
Posted on May 10, 2008
My water in my ice maker is warm and there is a smell like a backalite coming from freezer
Its not cooling properly,the issue is weak or dirty compressor section and related parts.Get the refrigerator serviced completely and see if its help.Otherwise compressor needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Our Whirlpool refrigerator model ED5SHAXMB10 is keeping our freezer food cold, yet no cold air is being blown into the refrigerator. Refrigerator is getting very warm. What can be done to fix it?
The defrost is not taking place on time or the defrost ventilation door is stuck closed.Its controlled by motor,that motor is got faulty.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
No ice refrigerator freezes runs constantly
SOME OF THIS NEW REF THE FAN WILL RUN CONSTANTLY IS NORMAN THEY USE VERY LITTLE ELECTRICYTY TO KEEP THE COPRESER FROM RUNING TO LONG.PART OF THR ENERGY STAR. THE ICE MAKER MAY BE BROKEN OR NOT GETING WATER. OTHER TINK CK THE ICE CREAM OR FROSEN JUCES TO SEE IF THERY ARE FROZEN HARD IF THE ARE SOFT THE MEENS THE FREZER IS NOT COOLING GOOD AND I/M WILL NOT MAKE ANY ICE IF IT NOT BELOW 10 DEGREES
Feb 21, 2012 | Maytag MFI2266AES Stainless Steel Bottom...
Ice maker just stopped making ice. had no problem up to a complete stop
Hi and welcome to FixYa, I am Kelly
First off make sure the water in door still works. If it does not work suspect the door / light switch.
Next make sure the freezer temp is below 16 Deg F. The ice maker has a thermostat that starts the ice harvest / fill cycle and if the freezer is warming up because of automatic defrosting problems (Ice build up on the evaporator coils) the ice maker will never cycle. If you note an ice build up in the back of the freezer compartment or poor air flow from the evaporator fan you have an automatic defrosting problem. If the fan is not running at full speed the bearings or windings on the evaporator fan are failing and there is not enough air flow to get the freezer to @ or Below 16 F.
Check to make sure the evaporator fan in the freezer and the condenser fan in the rear bottom of the unit are running un-obstructed. (clean as necessary.... but if the front of the cabinet is hot to the touch then the condenser coils my be clogged with lint or... the condenser fan is not running full speed.
The ice maker may be cycling but it may not be filling with water. If it is cycling but your not getting any water.... at all the prime suspect is the solenoid on the inlet water valve. The water valve is not repairable.
Make sure that the rubber fill tube on the back of ice maker is not blocked with ice... squeeze the end of the tube. If it is frozen with ice... the inlet water valve is bypassing water off cycle and causing the tube to freeze up. The only remedy for this is to replace the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kenmore elite in door ice maker is not working... 106.5770*701 water dispensor in door works, infrared sensor and on switch seem to be working properly and bin was removed defrosted and replaced and...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
or
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Kelly
Apr 16, 2011 | Kenmore Refrigerators
I have a model ed2nhgxtq00 whirlpool refrigerator. The problem I am having is that it doesn't make ice as fast as it used to. What do I need to do? Thanks!
First off check the freezer door switch for operation. Depress the plunger and make sure the light goes off when the door switch plunger is depressed. Light stays on = bad door switch / no ice production as the door switch provides power to the ice-maker when the door is closed.
Additionally in your case make sure that the evaporator fan is running at full speed. A slow running evaporator fan will cause the freezer compartment cooling to suffer.
Another thing that can cause the freezer temps to start rising is dirty condenser coils in the bottom of the unit. Make sure that the coils are free of lint and that the condenser fan is running at full speed. Usually when there is a problem with the condenser coil air-flow the cabinet of the unit will be VERY warm to the touch on the front in the door seal area. It is supposed to be warm.... just not VERY warm.
Here is a link to the steps on how to troubleshoot an ice-maker.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Let me just add that many ice-maker related problems are due to the freezer temp rising above 16 deg F. The freezer starts warming up due to ice build up on the evaporator coils and then the internal air-flow is blocked by the ice build up causing the temps to rise. Look closely at the back of the unit for any signs of ice build up.
If you see ice build up......
1. Unplug the unit
2. Remove the freezer contents
3. Place a fan directing air into the freezer for just over 2 hours. (Water mess!)
4. Clean up the excess water and restart the unit. (Add freezer content)
5. After 8 - 10 hours check for NORMAL ice production.
If after doing the above you have ice NORMAL production then most likely you have an automatic defrosting problem.
If it still does not make ice, the steps in the link above will isolate what has failed in the ice-maker.
Before testing the ice-maker using the steps in the link.. I recommend you peform a manual defrost with a fan. If 8 - 10 hours after the manual defrrost you do not have ice production,, use the link and troubleshoot the ice maker.
Here is a 2nd link for ice-maker troubleshooting that includes testing the optical system of the ice-maker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Your ice-maker parts and refrigerator can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135173&diagram_id=28114824#d28114824
The above link goes directly to the ice-maker but, using the diagrams on the left side of the page it will bring up all other sections also if you click on them.
Kelly
Jan 31, 2011 | Whirlpool Refrigerators
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
