Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
My tigershark runs for about 5 minutes then shuts down. it has been working fine twice weekly until this week.
    President:
  • AquaVac Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your problem could still be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. The models operate very similar to one another and troubleshooting them is the same.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 04, 2010
Why the engine starts, runs about 5 second, dies and then won't start, if you wait 10 minutes it starts and runs fine, this happens once every few weeks/months or twice in one day, no set pattern. hav
I saw what you replaced, didn't see any testing? What testing have you done? Make sure battery has a full charge?
When the problem is ongoing, have a helper crank it, while you check for spark at the plugs. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse. Any applicable trouble codes?
If you have the spider fuel system, that system is noted for problems.
Jan 28, 2018 | 1999 Chevrolet Blazer
Why my 1999 Chevy Blazer 4.3, engine starts, runs about 5 second, dies and then won't start, if you wait 10 minutes it starts and runs fine, this happens once every few weeks/months or twice in one da
You may be having an intermittent failure with the fuel pressure regulator - checking the fuel pressure when the truck won't start may pinpoint this problem. If the pressure looks OK, this same problem can be caused by the ignition system as well (ignition coil or control module).
13 HP Engine GX390 OHV Horizontal Shaft. runs perfectly fine/pressure fine for 2 to 3 minutes then shuts off. Have to restart over and over and over. Checked oil, no smoke, took air filter off, cleaned...
Check that the fuel tank is not creating a vacuum. this will starve the engine. After it shuts down the vacuum dissipates and lets the fuel run into the carb again.
Sep 10, 2013 | 13 HP Engine GX390 OHV Horizontal Shaft
Twice in a week my security light has come on and
disconnect the +battery post with an 8mm socket and leave the thing off for 2 minutes.reconnect it.
Jul 22, 2009 | Chevrolet Monte Carlo Cars & Trucks
2003 Jetta GLS (not TDI) alternator replaced twice in 2 weeks. WTH?
If the problem was in the alternator, the battery would have been discharged and you would not have been able to restart the car (unless jumped, but not have run for more than a few minutes before shutting down again) So, my answer: No.
Jun 02, 2009 | 2003 Volkswagen Jetta TDI
Dell Inspiron/HP 6940 stopped communicating
Have you removed the powe cable form the wall for 5 minutes?
Also check to see if another device has been installed or software recently that might have "overtaken" your printer.
Dec 02, 2008 | HP Deskjet 6940 InkJet Printer
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
555 people viewed this question
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
