Question about Epson Stylus DX4850 All-In-One InkJet Printer
How to remove epson print head for cleaning (stylusDX4850)
  • 74 Answers
-The printhead of this model is not user removable.
-It has to be disassembled by a trained technician to remove the printhead.
Posted on Sep 02, 2010
How to remove epsom NX400 print head
The print head on the NX400 printer is integrated into the ink cartridge and therefore when you remove the cartridge you are removing the print head. . . If you want to clean the print heads / nozzles then see the procedure in the NX400 User Guide in the section for Adjust Print Quality. . . .The User Guide can be found at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
How can I remove the print head for cleaning on a epson sx 405? thanks
Epson Status Monitor has a facility for cleaning print heads:
http://www.epson.eu/nbsp/Printers-and-All-in-Ones/Epson-Stylus-SX405/Drivers-Support?target=article&extn=.html&articleId=1702
If your prints are still streaking, try changing cartridges.
generally the print head cannot be removed on this type of printer, but if you plug the unit out and unscrew the outer casing, you will probably be able to get at the cleaning mechanism - usually a series of sponges used to wipe the printheads. the sponges may be full of ink - wear gloves! remove the sponges and clean them.
hope this helps
Jul 21, 2011 | Office Equipment & Supplies
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
I just installed a new black ink but it doesn't print black, only printed colors. I thought the ink was a defect so I changed another new ink but it is still not printing. Now, the color stopped working as...
your print heads might be clogged. clean it the hardware way. not the software way. to do this, simply buy a print head cleaning solution for Epson Printers. now pull out all your print cartridges and put a small drop of cleaning solution to the pin-like plastics in the base where your heads are seated. drop and drop cleaning solution to dilute clogs. you can use syringe to sip out the solution from the area. after this hardware cleaning, do a software cleaning through performing a cleaning print heads in the epson tools under maintenance tab
Oct 15, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
Jun 07, 2009 | Epson AcuLaser C1900 Printer
Epson r290 printer no printing now
try to clean yellow nozzle manualy, use a spuit and flexible pipa (as in cleaning mechanism), use a cleaner.
Feb 21, 2009 | Epson Stylus R290 InkJet Printer
How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
Dec 03, 2007 | Epson Stylus Photo 950 InkJet Printer
Epson Stylus DX4850 All-In-One InkJet Printer Logo
605 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
