Question about Panasonic PT-65WX51 65" Rear Projection Television
Pico fuses what do the pico fuses look like im not sure what im looking at
  • 395 Answers
The pico fuses look simular to resistors but are a solid color and has the value writen on it. the component location will start with "F" (Fxxx) or in some cases "PR" (PRxxx). F stands for Fuse and PR stands for PRotect.
Posted on May 10, 2008
What are the specific pico fuses for my RPTV
The amperage is marked on the board right next to them--likely if they go to the convergence circuit they will be marked 5a or 5 amp.
Usually but not always there are more at the convergence chips.
I presume you did not look closely at the board where the two you found are---Sony marks everything.
Jun 15, 2012 | Sony Televison & Video
I have a mitsubishi rear projection and im getting 2-2 error codes , tried replacing the 2 ICs and pico fuses and still doing it
Make sure +24V and -24V are present in power supply and being supplied to convergence output chips to solve 2-2 error problem.
Feb 13, 2011 | Televison & Video
My mitsubishi wd52525 tv went out when we had a power surge and now there is no power on it so i took it apart to check the fuse the only fuse i could find looked good a friend who fixed his said he had a...
that is the correct one but if you had a surge it would have fried a lot more than just the fuse surges are so fast they can even blow up a device and leve the fuse in tact i think it needs to see the doctor
Apr 21, 2010 | Televison & Video
Source for pico fuses for the Mitsubishi WD-62525 Power Board
Tries Websites Tv repair, and look for the pico fuses.
Mar 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
SD Tech you look like the man to answer my question! I Have a Sony KP-51HW40. I need to know how to try and manually adjust convergence. Tech mode? The flash focus button is not fixing it and i just want...
Call Mats Electronics they have everything 1-800-628-1118 and did you CK the pico fuses in front of your ICs and there is some behind them picos look like resistors they will be green or yellow 5amps 6 amps If convergence it not working after you hve replaced ICs CK the pico fuses.
Dec 31, 2009 | Televison & Video
Convergence problem philips rear projection tv.
All convergence circuits require two voltages which are equal, one being positive the other negative. Check the power supply for these two voltages and then see if you're getting them at the output ICs. I suspect one of them is missing or low. If there are no cooked resistors near the ICs, inspect the fuses that protect those two voltage sources or the regulating devices themselves.
Feb 16, 2009 | Philips 50PP9202 50" Rear Projection...
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Toshiba 57h82
Pico fuses could be through out the board... And the service manual, if it has a parts list, does give the board designation for all the picos on it...
Although these are good pictures they don't show a great deal of detail... But picture 1 & 2 at the far left, above where the two sets of blue wires are plugged in - looks like a pico piggy-backed on top of another pico... Sometimes it's easier than desoldering the original pico just to piggy back them in this fashion - but it's not a good practice.
Start there and read the designation on the board... Then look in the parts list section of the service manual and find the others by their designation.
Jul 24, 2008 | Toshiba 57H82 57" Rear Projection...
Pico/ Resistors what are these??
Pico means small and these look like little small resistors, but don't have stripes like resistors, just part numbers. They should measure as a dead short and be in the immediate vicinity of the STK's
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
171 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
