Question about Intermatic & Malibu& 300 Watt Power/Pack Timer
Please tell me how to set the dials for the lights to come on and off Thanks Cereta Doglerdogs@aol.com
I am using Word 2010 and I can't print labels on my Brother HL-5370DW printer. The red light comes on and it stops. I can't find a front tray for a manual feed. Got any ideas?
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=brother+hl-5370dw+downloads&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.brother-usa.com/Printer/ModelDetail/1/HL5370DW check out support please.
http://www.siliconguide.com/drivers/device/1609/
download drivers
Jan 24, 2013 | Brother HL-5370DW Duplex Wireless Laser...
Please e mail the intermatic timer instruction model# 59419 rosecthimote@aol.com
59419 is the Woods 2 pack plug in 24-hour dial timer with 2-prong outlet.
If this is not your timer, add a comment.
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
See all Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Manual for Woods 59419:
http://waterheatertimer.org/pdf/Woods-59419.pdf
Instructions:
Rotate dial until current time lines up with arrowhead located on inner dial
When plugged in, dial rotates
24 segments located around outer edge of dial; each segment is 1 hour
You have to pull these segments up using fingernail or small screwdriver
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
Plug lamp into timer
Make sure lamp is turned ON
Plug timer into wall
Dec 04, 2010 | Woods Hardware & Accessories
HELP PLEASE! My Fuji A900 does not shoot video
possibly the ribbon has come out of it's socket. Or it is damaged.
The selector dial on the back has it's own ribbon to connect it to the main pcb.
I have spare parts off an A800 If that's any help?
daveward712@aol.com
Feb 03, 2009 | Fuji FinePix A900 Digital Camera
Pilot light will not light
you should have to push the dial or a seperate button in to manually open the pilot gas valve. If you find this not to be true and you have a spark either the pilot burner assembly needs to be pulled and cleaned.
Dec 18, 2008 | Heating & Cooling
PLEASE, PLEASE try and help me...I can't tell you how much this would be appreciated. I have a Panasonic KTS4100 4 line phone (2 corded phones in our office, and one cordless). I have NO IDEA how to use...
Just in case you missed the manual:
http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
There are 2 conditions you need to be aware of
1 No DSL on the line
2. Set the intercom extension of the second phone
By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
Carl
Nov 25, 2008 | Lands Phones
Hello Slinte,
Good Day;
NO, the lamp will not cause this but the light engine or the cap's problem on the theboards will.
Good Luck, big IRISH.
Sep 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hardware acceleration is deactivated
Uninstall AOL. Do you have to use AOL or do you just like it. AOL causes more prblems with a computer than a VIRUS. I am sure that you did not want that as an answer, but it is the truth. Reformat your computer to remove AOL (THE ONLY SURE WAY TO REMOVE IT) Then use Earthlink if you have to use dial up.
If you want to keep AOL you need to try to upgrade your direct x. Ido not know what else to tell you. I hate AOL unless I am getting paid to remove it from a computer.
Apr 24, 2008 | Systemax AOL Optimized PC (100607) PC...
Signing on via AOL
Don't worry. Anything other than dial up will show up on AOL that way. If you have DSL or broadband you have tcp/ip settings. No virus. I know. I've had AOL since they were a baby. If this solved your problem or allayed your fears please rate this as fixed. So many people don't bother to rate. We live on our ratings. If you need further help with this just add a comment and I'll be glad to assist you further. Thanks much and have a nice day.
Apr 20, 2008 | Evesham Voyager 6400 Notebook
Phone got dial lock
Can anyone tell me how to open the dialing lock of panasonic integrated telephone system , for which the password is lost.
please waiting reply
Dec 09, 2007 | Panasonic KX-T7636BK Digital Telephone...
CAN'T GET AOL DIAL UP CONNECTION TO WORK
This error message normally happens because of a corrupted driver. Reinstall the driver for your modem.If you do not have cd's that came with your computer go too acer's website to download here
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4309542&CFTOKEN=82834010
Now if that is not the cas maybe you are incorrectly installing aol. Start up your aol. If it specifies broadband at login box change to dialup or go to setup and let aol automactically detect your modem. If problem still persists. Reinstall software when prompted make sure you select dialup. Now if you are using broadband and asking for dialup. Or go to the control panel and remove your modem driver, shut down and restart. It should put the modem back.  Any more questions post comment.
Hope this helps you
Oct 25, 2007 | Acer Aspire 3680 Laptop
Intermatic & Malibu& 300 Watt Power/Pack Timer  Logo
24 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
