Question about Garden
What is the fuel/oil mixture for the poulan 330pro chainsaw? What type of oil should be used? I lost the manual. Thanks, Camillo.
  • camillo_pera Sep 02, 2010
    Many thanks. What kind of oil you use? SW40 or 30?
  • camillo_pera Sep 03, 2010
    Many thanks, again. All the best, Camillo.
  • 132 Answers
SOURCE: Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Posted on Nov 15, 2008
  • 62 Answers
SOURCE: lost manual - what type of oil does this chainsaw
I assume you are asking about bar oil. Most electric chain saws use 30 weight non detergent oil for the bar (the cheap stuff from your local walmart).
Please do not try to use bar oil intended for gasoline powered saws, as it is formulated to be very thick, and will not flow properly, wearing out your bar and chain prematurely.
Posted on Apr 17, 2009
  • 120 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
SOURCE: Replacing a fuel line for a Poulan 2175 type 2 chainsaw
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Posted on May 14, 2009
  • 67 Answers
SOURCE: Fuel Mixture for a Poulan Wild Thing
as far as i know it is 1:40, or 3.2 ounce Oil to 1 Gallon unleaded regular fuel
Posted on Jun 06, 2009
Lost my manual for my Poulan wild thing 2375 chainsaw and I want to fill it up with oil and fuel.
Fill the oil tank at the front of the saw with a non fling chain oil, or as thick an oil as you can get, fill the fuel tank with a 25-1 fuel oil mix, use a good, well known brand of two stroke oil designed to be used in chainsaws.
Jul 15, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas.
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
Gas/Oil Mixture, 50 to 1 or ?
All major manufacturers recommend 50:1;
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
with the exception of McCulloch and Poulan 40:1 and Chinese chainsaws 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Looking for manual for Poulan countervibe 3700 What is the oil to fuel ratio?
IAW with specifications here (40:1 - 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil)
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/00c68f320e8e63ba88256bf80016a58c?OpenDocument
The OM for a 3700 is not loaded. Please try here:
http://www.poulanpro.com/node4033.aspx
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 1gal premium/4oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Feb 15, 2010 | Poulan Garden
Fuel mixture for Poulan 245 and 306 chain saw's
245 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/30945e6822106f5388256b3500246efa?OpenDocument
306 here
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9a98d7ae6c77deaf88256b350024ae42?OpenDocument
I use 50:1 in everything.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
Lou
Jan 26, 2010 | Poulan Garden
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman 16'' 36cc's oil to fuel mixture, and bar oil requirements
Your Craftsman is probably a Poulan, for the past few years Poulan has recommended a 40:1 ratio 1 gal premium/3.2 oz quality 2-cycle engine oil. I'd thin down even a little more 50:1 (1 gal premium/2.6 oz quality 2-cycle engine
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
For the bar every home center and hardware sells bar oil. It is 30 weight non-detergent oil with a few additives to help it adhere where lubrication is needed. HTH
Lou
Nov 16, 2009 | Garden
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
