Question about ViewSonic VA2226w 22" Widescreen LCD Monitor
My monitor turns to black screen every 4 seconds. its a viewsonic 2235 wm3
  • 11,361 Answers
Look for bad caps in the power supply first, post back what you find.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 03, 2010
My Viewsonic 2235 monitor only shows the desktop top on 70% of the upper screen. It was fine and I ran Paretologic. When I rebooted, the screen images are egg shaped or stretched out side to side. ...
If you have an Auto Adjust option on your monitor, press that and it should adjust the screen to the correct size.
The button should be on the panel or it might be a setting in the monitor settings itself.
Hope that helps
Dec 15, 2010 | ViewSonic VX2235WM Monitor
The Screen comes on for 1 second then goes black but you can still faintly see the image on the screen
It can be as simple as bad DC filter caps (leaking/bulging tops), that will be the first thing to look for, it can be more serious problem in the inverter circuits or bad CCFL assemblies.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Sep 06, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Shuts off to a dark grey, turn VS power off>baon to display image
You may have failing DC filter caps in the power supply just like Viewsonic monitors you can see in my albums, you is about the same as 2235.
If you are not going to DIY you will be better off putting the money toward new monitor, estimate repair up to $100.
Jun 24, 2010 | ViewSonic VX2035WM LCD Monitor
Can I connect two mac computers to a Viewsonic 2235 and switch between them
Yes, purchase a kvm (keyboard, video, mouse) switch. They are usually arranged as dual, quad, and eight. Just push a button and it cycles between them in order (toggles back & forth on a dual). Anything more than two is usually used on a server rack to control multiple servers with one keyboard, mouse & monitor. I use a quad myself. You can get one on ebay, staples, office depot, compusa, etc.
If this solution helps to solve your problem, then please take a moment to rate it.
Jun 02, 2010 | ViewSonic VG500b (Black) 15" LCD Monitor
Shuts video off when gets hot turn off and
Look for bad caps, bad solder joints on the circuits board, etc.
the 2035 is almost the same as 2235. Please look at failed VIEWSONIC monitors here so you will know what to lookl for inside.
http://www.badcaps.net
Apr 23, 2010 | ViewSonic VX2035WM LCD Monitor
Blue power light is on but screen remains black
Common problem with 2235/2245 is failed capacitors in the power supply/inverter board combination. You need to get the P/N and names of the board since there may be more than one version of the assembly for the same model.
When you get the information, then you can check here: http://www.lcdparts.net
Post back so it may help other people also.
Apr 09, 2010 | ViewSonic VX2235WM Monitor
Viewsonic monitor goes black one second after startup screen boots up. Fix for this? thanks
plz log in safe mode and then disable the display adapter from the device monitor then log back normally and check whether problem is solved or not
Apr 29, 2009 | Computers & Internet
Viewsonic Monitor black screen but when turned off and then on-the screen will come up for a couple seconds and then go away
this problem have 2 posiibilities
1)solder lose on the vedio socket and around horizental circuit
2) the line
and mostly in viewsonic and compaq its the line wich you need to replace it if you can find it in the market
Oct 30, 2008 | ViewSonic Computers & Internet
ViewSonic VA2226w 22" Widescreen LCD Monitor Logo
211 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
