Question about Polaroid CAA-03040S Camcorder
Turning off I have not used my camcorder since i videoed my friends snowboarding...i forgot how to turn it off?
  • Bob Easy May 25, 2008
    New unit. Turned it on to learn about it and now it will not shut down. Seems to be "frozen" on and will not respond to any "commands."
  • lynnlongo Dec 25, 2008
    Camera keeps turning off. Has new batteries.
I removed batteries and then reinstalled them. It now works fine.
Posted on May 25, 2008
Simply closing the flip open screen should turn it off or there is a power button under the screen.
Posted on May 10, 2008
Highback plate latch is backwards.
I would google the following sentence: "snowboard High Back plate latch is backwards" and check if any of these articles are referring to the problem
Feb 10, 2013 | Lamar Snowboards Lamar MX5 Snowboard...
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
I forgot my password, how can I reset it.
Via Da Kine FAQ's:
Q: I have forgotten the combination to my Cool Lock, can you tell me what it is?
A: Unfortunately we do not have the capabilities to know what you chose as your original combination.
Best bet would be to write down numbers that have significance to you since you set the combination originally and try various combos or if all else fails brute force it. Turn on some TV pull up a comfy seat and get to work finding one of the possible 1,000 combinations.
Dec 28, 2010 | Da Kine Dakine Cool Lock Ski Or Snowboard
Are Siren snowboards any good? If so why can't I find a website for them?
Siren makes awesome boards. My GF has been ripping on one for almost 3 years and it is her favorite board ever. They only make womens boards and they do it right. I want a board as light and strong as hers. Hahhh!
Jul 21, 2009 | Ride Snowboards Ride 09 Womens Siren 144...
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
Not able to download video from my JVC-GZ-MG130 Camcorder
if you are using a memory card , get a memory card reader that will work in a usb port on your computer
Mar 05, 2009 | JVC Everio GZ-MG30 Camcorder
Deleted footage off my JVC hard disk camcorder Everio GZ-MG30
There is a way to get back those deleted video files from your digital camcorder, BUT it is just possible. Because if those deleted files has been overwritten by new files you saved in, then there is no hope. However usually overwritten cases are hard to happen as long as the hard disk(of your JVC camcorder) has enough volume.
Then, take so called data recovery program to handle the issue and see if you can grab some or all of the deleted files back. Here are some recovery software you may take a try.
If you are running Windows, try this video photo recovery program.
If you are using Mac OS X, turn to this Mac photo video recover software.
You should take care - before your files are recovered, do not save more files to the device concerned(do not take more videos or photos) in case overwritten situation will happen. I hope you good luck.
Jan 02, 2009 | JVC Everio GZ-MG30 Camcorder
Is there a different type of bindings for each type of riding?
Technical freestyle This type of rider is most often found on the lower elevations of the mountain, hiking the halfpipe or riding in the snowboard park. Many of today's technical freestyle riders come to snowboarding with experience as a skateboarder, in-line skater, BMX, or other action sports background. While the equipment specific to this type of rider excels in park and pipe riding, it can also be very versatile across the whole mountain at less than full-speed. * Technical freestyle bindings o Technical freestyle bindings generally use a low hiback with 2 straps for increased flexibility and range of motion o These bindings are not usually value/price driven o Most technical freestyle bindings (either step-in or strap) are made of composite materials in vibrant colors o Riders generally gain responsiveness with a minimal weight gain Freeride While an overused term in snowboarding, freeride is still the best way to describe the majority of snowboarders and soon-to-be snowboarders. As it suggests, freeride describes a user who intends to utilize the whole mountain. These riders enjoy everything about snowboarding: the amazing feel of carving a turn on freshly groomed slopes, the sense of flight obtained at lift-off from the big-air jump, the creativity that can only be understood descending the half-pipe, and the feel of freedom one gets floating in fresh powder. * Freeride bindings o Freeride bindings generally have higher hiback with 2 or 3 straps for added support and control o These bindings come in every shape, color, and price o For the most part, no matter what the specifics of each freeride binding, the general effect on the riding experience is minimal. This holds true for both traditional/strap bindings and Step-In bindings. o Binding choice is commonly a packaging decision or one of brand/price/graphics Freecarve This type of riding style is one of the fastest growing segments within the snowboarding world. Commonly referred to as "cross-over," a majority of these riders were once skiers. A freecarve rider enjoys the full-length and width a mountain has to offer, continually transitioning from one turn to the next. * Freecarve bindings o As with freecarve boots, there are very few freecarve bindings o Those that are freecarve specific can usually be distinguished by their third strap o Step-In bindings are also available in a freecarve configuration, and are almost always manufactured from space-age composites Alpine/Race Alpine/Race riders are easily picked out of the crowd. They are always seen on groomed trails, laying a trench in the snow with each turn. These riders use a snowboards edge like no other rider. Using powerful body movements and gravity as their friend, alpine riders enjoy the sport only when they are connected to the snow. * Alpine/Race bindings o Alpine/Race bindings are usually a plate binding with hard boots o Metal and composites are the only available materials for this type of binding
Dec 01, 2008 | Flow M9 Snowboard Binding
Snowboard type or styles
"There are Three Different Types of Snowboards available on the market today: Freestyle, Freeride (All Mountain), and Alpine (Carving) Boards. Each board has a unique construction technique and materials, shape, flex pattern, and size. The type of Snowboard you ride should correspond to your particular style of riding. Freeride or All Mountain Board Freeride or All Mountain Snowboard Of the three Snowboard types, the Freeride Snowboard is the most popular. Accounting for half of all Snowboard sales, this type of board is a good all-mountain, park and Halfpipe Snowboard that is designed to float well in Powder Surface. You can enjoy carving, catching air, and basically all riding aspects with this type of Snowboard. Freeride boards have a directional shape and are meant to be ridden primarily in one direction. Having a directional shape means that the Snowboard's tip is different from its tail. In freeride, the tail is generally more narrow, shorter, and flatter than the tip of the board. With this, the stance on freeride boards is usually offset toward the tail of the board. Still, freeride boards can be ridden Fakie, despite their directional shape. Freeride Snowboards are usually fairly soft and maneuverable enough for beginners, but stiff enough to hold a fast turn in hard snow. This type of Snowboard bridges the gap between Freestyle and Alpine carving. However, it isn't as stable as a carving board and it isn't as agile as a freestyle board. Freestyle Snowboard Freestyle Snowboard A Freestyle Snowboard is wider, more stable, and more forgiving to ride. Also, it is shorter, lighter and (compared with a freeride board) softer in flex, which makes it easier to turn. These characteristics make a freestyle board very responsive to the rider. Consequently, it is the best choice for the beginner. These boards are built mainly for performing tricks in terrain parks and halfpipes (e.g. spins, air, grabs and riding fakie). Still, Freestyle Snowboards have limited edge grip and stability, and are not good for carving turns or cruising fast. Most Freestyle Snowboards are either twin tip boards or directional-twin. Twin tip boards have a centered stance with a tip and tail that are exact copies of each other, making them symmetrical in shape. Both ends of a freestyle Snowboard have a shovel, and freestyle boards with twin tip design makes it easy for beginners to ride both forward and backward (fakie). Directional-twin Snowboards are similar to the regular twin tip Snowboard; only, its tail is stiffer than the nose. Carving, Alpine, or Race Board Carving or Alpine Snowboard Carving Snowboards are narrower than freestyle and freeride boards. Their long, narrow, stiff constructions are configured for higher speeds and cleaner carved turns. With this, carving boards allow quick edge turns, swift, superior edge-holding power on hard snow, and good stability for speed. Also known as alpine boards, these snowboards almost look like an enlarged Ski. They are made in both symmetrical and asymmetrical styles and tend to only have a shovel on the nose. Similar with freeride boards, carving boards are made to ride only in one direction. While carving boards offer a higher level of performance, they are more difficult for the beginning rider to use and are generally reserved for more advanced riders. Alpine Snowboards are mainly preferred by Snowboard racers for a great day of fresh unridden powder. Keep in mind that alpine Snowboards are configured for riding and carving downhill, not for doing tricks. To summarize, freestyle, freeride, and alpine or carving Snowboards are the three basic types of Snowboards. It is easier to maneuver a soft-flexing, twin-tip, gradual side cut Freestyle Snowboard. On the other hand, it is harder to maneuver a stiffer-flex, directional, aggressive sidecut All-Mountain Snowboard with scores of combinations in between. Always remember that the type of Snowboard you ride should correspond to the type of riding that you like to do, and that both Freestyle and Freeride boards are good Snowboard types for beginning snowboarders."
Dec 01, 2008 | All Star Forum Star Women's Snowboard
Polaroid CAA-03040S Camcorder Logo
64 people viewed this question
Top Polaroid Video Cameras Experts
Timllfixit
Eric Sutherland
Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
