Question about Watches
I Have a Guess prism watch, I14503L1. I can change the time and the date, but not the day. Any ideas?
  • 29 Answers
SOURCE: Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Posted on Mar 11, 2008
SOURCE: LOST MANNUAL-UNABLE TO RESET THE TIME/DATE/..NO IDEA ?
Please use the manuals available at these links
http://glen.utdallas.edu/Glen/Manuals/Timex/Timex%20Expedition%20Instr.pdf
http://glen.utdallas.edu/Glen/Manuals/Timex/w6Instr.pdf
Posted on Jun 11, 2008
SOURCE: HOW TO CHANGE DATE
I have an old analog quartz Timex watch with a mechanical day and date display. The stem pulls out to only one position which moves the hands. As the hands are rotated past the midnight (not noon) position the date changes first and then the day.
The simplest way I found to adjust both the day and date is to advance the hands forward through the midnight positions until you reach the desired day. As soon as the day clicks into the desired position back up the hands through the midnight position to about the 10 pm position. This resets the mechanism to set the day/date. Then advance the hands towards the midnight position carefully until the date changes and before the day changes. Again back up the hands through midnight until about 10 pm and then forward to advance the date, stopping before the day changes. Repeat the last two steps until you get the correct date. Then rotate the hands back to the correct time, if it's a morning time be sure to rotate all the way back through 12 noon to the correct time. Hope this helps.
Posted on Aug 26, 2008
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
  • 26 Answers
SOURCE: Day setting problem
you have to keep adjusthing time froward for 24 hours for the day to change its a pain in the *** but ist the only way
Posted on Jul 13, 2009
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Watch setting instructions guess w0041g1
You should have a button above the crown which you push to change the month. The crown is a 2 position crown.....if you pul it all the way out you can set the time, but if you push it in just half way, you can change the day and date by either turning the crown backwards or forwards. Good luck
Nov 26, 2013 | Watches
My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Jun 04, 2011 | Guess G85675G WristwWatch
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
Nov 14, 2010 | Guess Watches
Day/Date change
The date on mechanical and automatic watches change normally between 2-4am because this is normally when people sleep. It is not broken or in need of overhaul. It has to change sometime and that is what they have tradionally used as a time for the date to change. Also remember it is normal for an automatic or mechanical watch to loose or gain time friction is the culprit here since the gears do mesh with each other.
Fine watches like Rolex and Omega are beautiful watches but expensive to have cleaned. It should be cleaned about every 10 years or if it starts to loose a lot of time.
Incidently most agree that the Omega speedmaster manual wind (The watch that went to the Moon) is the most accurate of the bunch and is very sought after by collectors!
Apr 10, 2010 | Guess Dress Bracelet 87000L1 Watch for...
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
Day setting problem
Jul 13, 2009 | Guess Collection Textured Dial Watch
Type of battery for ladies guess watch
I have a guess W15514G2.. and I want to change the day in the watch, In the first click I am able to adjust Date on one side and month on the other side, the next click makes me adjust the time. But what about the Day? How do i adjust that? Help me
Jul 13, 2009 | Guess G66355L Wrist Watch
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
Change day on dial
Pull out the crown to the first click- the watch is in day-date setting mode. Turn the crown one way- the date will change. Turn the crown another way- the day will change.
Rate me, please.
Mar 21, 2009 | Guess Collection Textured Dial Watch
Watches Logo
274 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
