Question about Whirlpool Water Heaters
To check the elements hot water hearter stop heating.whirlpool electric
  • 20 Answers
While the power is off to the water heater it's safe to remove the access panels. Once the elements are exposed a multimeter that is set on the Ohms can be used. The average reading of a good element is around 12 ohms. This can range a few ohms up or down. If you don't get a good reading the element will need to be replaced.
If the water heater has two elements the top element should be checked first. When a Whirlpool heater has two elements and the top goes out this will cause the water heater not to heat at all.
If both elements show they are good it would be recommended to contact the manufacturer. The technical support line for the Whirlpool water heaters is 1-877-817-6750.
Posted on Oct 02, 2010
Electric water heater stopped working
The unit doesn't like to drain without air coming in on top of water, so flushing with pressure applied is the preferred way. Be careful, see if you have power coming into unit. Turn off power and open the connection connection plate I would suspect that if the breaker is supplying power, sometime I have found that the connections are not properly made.. . If you a timer to limit operational hours take it out and go directly to romex from breaker panel.I f water starts hot and then go cool very quickly the bottom heating element and or thermostat is not working. Remove lower element cover and with power off check element resistance you can compare upper and lower element readings. From experience I never repair water heaters: time and material is more than new unit. You will need to buy element socket heating element(s) and or thermostat(s). In the end you still and old water heater.
Apr 20, 2017 | Whirlpool 28 Gallon Electric Mobile Home...
Tip
Electric Water Heater not Working
If you have an electric water heater and it is not making any hot water then you have a problem. The good news is that electric water heaters are not that hard to troubleshoot and there are not a lot of things that can go wrong with them. I will go over the things that can give trouble and how to fix them.
First off if you have some hot water but not as much as you did when it was new then you probably have a bad bottom element. Only the top element is working, so you are only getting about 1/3 of a tank of hot water, replace the bottom element and you will be good again.
If you are making steam, then you have a bad thermostat. While you are making the steam out the relief valve, check to see which element is working. The easiest way to do that is to see which element has 220v on the two screws on the element. That thermostat at that element is bad. Replace it and you will stop the sauna.
If you have no hot water then check the red reset button directly above the top thermostat. You may have to push very hard on it to get it to reset. If the reset is tripped then you have a bad thermostat. Finding out which one can be tricky and timing is important to catch the bad thermostat in the act.
No hot water can also be the result of the top heating element going bad. If the top element goes bad then the top thermostat will never get enough heat to trip on the bottom thermostat. Therefore you will get no hot water. Dual element hot water heaters for residential use, do not ever run both elements at the same time. Only the top OR the bottom will be energized at a time.
This all there is to checking an electric hot water heater. If you are having problems go through this list systematically and you will find your problem and be able to fix it.
For a diagram of how a typical electric hot water heater is wired, check out this tip.
http://www.fixya.com/support/r4422595-electric_water_heater_wiring_diagram
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
http://www.fixya.com/support/r4656414-replace_thermostat_element_electric_hot
http://www.fixya.com/support/r4041115-clean_hot_water_heater
http://www.fixya.com/support/r3689051-home_water_heaters_hot_water_heater
on Apr 28, 2010 | Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
Water is not getting hot
1) Copy following link for detailed troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) How are you testing a 240Volt water heater and getting 12.5? Or 60?
Dec 15, 2012 | Whirlpool Water Heaters
Hotwater heater new won't heat??
Is water inside tank Hot?
Open TP valve and also open drain valve.
If tank is hot, then you might have plumbing problem caused by bad faucet cartridge or check valve.
Red reset button is located on upper thermostat.
Test for 120Volt across top two screws on upper thermostat.
You might have a bad upper thermostat.
If electric water heater has some hot water, then upper element is good.
Electrician should enjoy following page full of information.
Are the hot and cold pipes reversed on top of tank?
Usually the cold water line has shut-off valve.
Top of tank is marked H and C
http://waterheatertimer.org/How-it-works.html
Aug 23, 2012 | Whirlpool Water Heaters
Hello - I have a 6-7 yr old Whirlpool EnergySmart 50 gallon 5500 watt water heater. (Two control boards fried and were replaced free). Symptom now is not enough hot water. No 'error codes' are blinking...
1) Residential water heaters are non-simultaneous. Only one element works at a time.
Upper element comes on until top of tank is heated, and then lower element is switched on until lower part of tank is heated. Lower element keeps tank hot during standby hours
2) Typical Whirlpool energy smart has 4500Watt elements. Look at label on side of tank
If both elements were ON, that would draw 9000Watts or 37.5 amps, requiring 50 amp breaker and 8 gauge wire. V x A = Watts.
All dual-element tanks are 240V.
Whirlpool energy smart requires 10 gauge wire and 30 amp breaker so electronics are not starved during operation. If your wire or breaker are undersized, that is suspect for repeated failure.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Typical electric water heater heats 21 gallons per hour. First hour delivery is higher since elements heat water as you use it. Overall however, electric water heater cannot re-heat as fast as gas because gas water heater burner carries more BTU punch per minute than electric element. Gas heats about 41 gallons per minute, with higher first hour delivery.
4) IF YOU HAVE OLDER energy smart and installed newer board, then you could have non-simultaneous operation is reversed so that lower element comes on first.
Read following post at Fixya:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Contact Whirlpool 1-877-817-6750
5) Another potential problem is that you have sediment inside tank and that is reducing efficiency of lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 09, 2011 | Water Heaters
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
Water Heaters Logo
185 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
