Question about Sewing Machines
Re-inserting bobbin case on a Singer 4552 sewing machine
I have a Singer 4552 machine.  While sewing today, the black, plastic bobbin case popped up and out of it's proper location.  I have tried to re-insert it, but it doesn't seem to "seat" correctly.  My owner's manual is of no help.  Please help!
  • Jackie May 13, 2008
    I tried the suggestion, but the case still doesn't seem to seat properly.  I may end up taking it into a repair shop. :(  Thanks anyway.
    New Friend:
Same problem. No help at all from manuel. Just glad to hear others are familiar with problem. Thought it was just me!
Posted on Feb 26, 2015
  • 18 Answers
SOURCE: How to replace the bobbin case in a singer sewing
If you go here and search for 9005, you can find a free downloadable instruction manual.
http://www.singerco.com/accessories/manuals.html
Posted on Jul 22, 2010
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
How to reinsert the bobbin case on singer 4552
just raise the little lever on the bobbin case, slide it on the metal "post" then let go of the lever.
Oct 08, 2014 | Sewing Machines
In my futura ce-150, when I try to sew the machine pops up my bobbin casing and stops sewing. It pops it up with such force the plastic door comes off and the casing gets tilted. I have tried multiple...
Your problem sounds like the thread is jamming under the bobbin basket. This can be caused by the retainers for the bobbin being out of adjustment.
Aug 12, 2013 | Singer Sewing Machines
I have a singer 7468. THE BOBB IN CASE KEEPS POPPING OUT. CAN THIS BE FIX?
the sewing machine may need a new bobbin case,, but I would
suggest take the sewing machine to a repair shop to see if there
is something wrong with the hook & hook race,,that may be why
the bobbin case is coming out.
Oct 06, 2012 | Singer 7468 Mechanical Sewing Machine
Singer quantum xl-600 bobbin case spinning
sounds to me like you need a professional cleaning and timing adjustment.
Jul 09, 2012 | Singer Quantum XL-6000 Computerized Sewing...
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
How do i lift up the needle plate to insert the bobbin?
You will see what looks like a square black button directly to the right of the bobbin. It doesn't depress, it slides to the right, and then the plastic that covers the bobbin should pop open on it's own.
Oct 28, 2011 | Singer 4423 Sewing Machine
How do i insert black plastic bobbin case back into singer 57817c
Sometimes they have to go in at a very specific angle before they will seat properly. Other times you have to take off the metal cover to get it in there.
Unfortunately all the manuals are at a cost online, so I can't take a look to advise from the instructions.
Mar 02, 2011 | Singer 57817 Computerized Sewing Machine
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Mar 17, 2009 | Singer Featherweight 132Q Mechanical...
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
906 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
