Question about Sony STR-DG510 Receiver
Sony HDMI receiver STR-DG510
How do I set other FM channels on the receiver, there are 30 preset digital channels. Thanks, Bill
  • 3 Answers
On Page 54/55 of user man. has a step by step instructions.
Posted on Jun 02, 2008
  • 1prosource Jun 02, 2008
    1. press turner to select fm or am band.
    2. Tune in the station you want to preset
    3. Press Memory
    Memory lights up for a few seconds. Perform steps 4 and 5 before “memory” goes out
    1. Press the numeric buttons to select a present number
    2. Press Enter
    3. Repeat steps 1 to 5 to preset other stations
How do u reset soney reciver str-dg510 i have no sound
What preceded this? Was it working and then stopped or did it never work?
http://www.retrevo.com/support/Sony-STR-DG510-Receivers-manual/id/2526ci754/t/2/
Page 26...
Press I/O to turn off the receiver
Hold down I/O for 5 seconds (("PUSH" and "ENTER" apear on the display alternately)
Press MEMORY/ENTER. After "CLEARING" apperas on the display for a while, "CLEARED" appears.
Jan 31, 2011 | Sony STR DG510 - AV receiver - 5.1 channel...
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
I hooked up my newly purchased Sony BDP-S560 with HDMI to my projector for video, optical cable to my Yamaha RX-V750 for audio. I tried several audio setting with the BDP-S560. However,I cannot get any...
It sounds like the BDP unit is set to downmix PCM to the Optical Digital Audio output (the default). You need to change it to something like Dolby Digital. Crack the manual and look at all the digital audio settings you need to choose.
Aug 04, 2010 | Sony STR-DG510 Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Aug 01, 2009 | Sony STR-DG510 Receiver
Sony STR-DG510 From component to HDMI
You have to use the same connection in and out. You can not mix inputs and outputs (Example- HDMI IN will not play on Component out and Vice Versa.)
Nov 18, 2008 | Sony STR-DG510 Receiver
DOES NOT PICK UP FM CHANNELS CLEARLY
Does the receiver work for AM? I need to isolate the problem circuit. Please try an AM station and update this.
Thanks,
Dan
Jul 29, 2008 | Sony STR-DG510 DTV Receiver
No video output using either HDMI or component video
Make sure that these inputs are enabled. I'd have to confirm within the manual, but I believe that these have the HDMI section disabled by default.
Dan
Mar 21, 2008 | Sony STR-DG510 Receiver
Sony STR-DG510
I think you have to run a separate audio line from the dvd to the 510, because the HDMI is only passive
Mar 12, 2008 | Sony STR-DG510 Receiver
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
Sony STR-DG510 Receiver Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
