Question about Sony DCR-HC52 Mini DV Camcorder
The touch screen of my sony dcr-hc52 video camera has stopped responding entirely. i can still record and enter cassetes but the touch screen has stopped responding. what do i do?
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon connector between the LCD and the camera body and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
ctf1800
  • 4402 Answers
SOURCE: Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Mar 17, 2008
SOURCE: sony camera recorder DCR-TRV285E HARD WARE PROBLEM
i cant view m photos
Posted on Feb 12, 2008
  • 9 Answers
SOURCE: Handycam DCR-HC21: LCD touch keys does not work
try alamocamera.com for repairs
Posted on Jul 30, 2009
  • 497 Answers
SOURCE: camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
SOURCE: Imac 9pin firewire port does not recognize my Sony DCR-HC52
Perhaps a USB to Firewire dongle will help sort you out. As you have discovered those two are not compatible. To make it work, you MUST get a 4 pin card and install it, or the USB solution.
Posted on Mar 14, 2010
Where can I purchase battery charger for Sony DCR-HC52 mini DV handycam?
Your local friendly camera shop, or Ebay - or Sony themselves.
Jan 10, 2017 | Sony DCR-HC52 Mini DV Camcorder
Touch screen has stopped responding on our DCR-sr100. Is there anything I can try to fix this problem. We can no longer download video from the camera to the computer without a working touchscreen. Camera...
You could try removing the battery, and reinstalling the battery to see if the touch screen starts working again. If it doesn't, this device will need to be sent in to Sony for repairs.
Find a location to get your Sony product repaired, the Sony repair cost, and to initiate the repair procedure. Here is a link to Sony's Repair site: https://eservice.sony.com/webrma/web/index.do
Apr 14, 2011 | Sony Handycam DCR-SR100 Camcorder
My Sony Handycam DCR-HC52 has black lines during playback. Used cleaner tape because would not record either. Now recording but still has lines during playback.
This is usually caused by an oxidized or defective Audio/Video drum. If you've tried running a cleaning tape through the camera and it still does'nt work the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Dec 16, 2010 | Sony DCR-HC52 Mini DV Camcorder
Do not work my sony handycam DCR-HC52 touch system
Its LCD flex cutoff so that touch panel is not working it need to be replace
Feb 26, 2010 | Sony DCR-HC52 Mini DV Camcorder
The touch screen is not responding. It will record using the button on camera but not able to see playback using touc screen
hi,
its just rutting problem in same models , you just need to change lance flex,change it and you find magic .
Feb 08, 2010 | Sony DCR-HC52 Mini DV Camcorder
Touchscreen stopped working, the screen is there, but the touchscreen does not work
do not work my sony handycam DCR-HC52 touch system
plz
send me the solution of this problums.
thanks
Jan 16, 2010 | Sony DCR-HC52 Mini DV Camcorder
No Video
if it shows blue screen, the head may be dirty, cleaning cassete may solve the problem.
Mar 25, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony DCR-HC52 Mini DV Camcorder Logo
401 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
