Question about Canon IMAGERUNNER 2230 Copier
Hi! I must change the OPC drum from IR 2230. I dont know how to do this. Thank you!
  • 1,219 Answers
do you have original drum cartridge or only drum, blade and charge roller?
For complete unit exchange, you can contact me on emma.servis@gmail.com, for service manual.
Best regards!
Posted on Sep 03, 2010
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
1020 drum laserjet
The OPC drum is contained inside the toner cartridge.. just buy a new toner cartridge! OPC stands for (Organic Photo Conductor) and its part of the toner cartridge.. Buy a new cartridge HP order number is Q2612X or aftermarket
Feb 04, 2014 | HP LaserJet 1020 Printer
How do i change the drum unit
It involves some dissassembly on that model. You must remove the white front cover......the waste toner bottle....remove a black screw to be able to release the developer unit pressure ......and screws that secure the drum unit. If you are not a technician you might not want to try it. Or buy the service manual online which will tell you in detail how to dissassmble and install the drum.
Jul 23, 2012 | Canon IMAGERUNNER 2230 Copier
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
HOW DO YOU CHANGE A CLEANING BLADE IN A CF900 COPIER
Remove the OPC drum unit,remove the OPC drom and change the cleaning blade(fixed 2 screws).Normally if you change the OPC drum change automatically the OPC cleaning blade.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
How do I change the drum on the Canon 2880
Open the fron door ,diss/assably the developer unit.Remove the OPC drum and the chasrge corone unit.
Dec 11, 2009 | Canon IMAGERUNNER 2230 Copier
Canon IR 2830 how do I install drum assy? How do I put in a drum unit for the IR 2830.
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it.
B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
Nov 22, 2009 | Office Equipment & Supplies
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Four dots middle of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Sep 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
120 people viewed this question
old marine
old marine
